New BR disks - File is corrupt
GuruMeditation
#1 Post by GuruMeditation » Sun Mar 02, 2014 9:55 pm
I've been encountering some problems with two new BluRays I picked up at Wal-Place. Carrie (2013) and Thor 2. Problem does not appear to be related to the 1.8.9 bug (though it could be). Ripping both disks with either decrypted and encrypted video yields the same result. In both cases the affected tracks would be the movies themselves.
Debug log started at Sun Mar 2 20:31:31 2014 , written by MakeMKV v1.8.9 linux(x64-release)
001005:0000 MakeMKV v1.8.9 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/fws/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at Ld9WMw}rmZ+Bd.G [PV[10V:213130122
005072:0000 Backing up disc into folder "/home/fws/Rip/backup/MARVELS_THOR_THE_DARK_WORLD"
DAFD=PAAAADAAAAEABDQkEHgACAQ==
DCE=rpgstJGHuuSFaTmZbRBHkd4Ut6rG+0/U/lAJY78ostgyQwCzENKRGzQEF3A7nG+3QdUqzcn7Ps47r6WI9mBSwmo2IxC3NGM+9X+h+7O6Uz5R6ijN8xfLK42BnMSMJSFhCfxrOiY/+n35OEQRBIr77F1tCviCrFZC6g==
DCE=wwQil++qI6kKRI3fRu/TuIARLqA41I8bspzVmrtyulsPMj4haGaO/p77XaZmU31ClAOIyhhugGzTh7HiyIZeotysdebJfw+n4zIwiSLSNmB0CYFTjQCLA/G2C82uwGDmP3uL+dnlxY+EkHGWfspXrqu+brallqCC9g==
002021:0000 Unable to open file '/BDMV/STREAM/00887.m2ts' in OS mode due to a bug in OS Kernel. This can be worked around, but read speed may be very slow.
001003:0020 DEBUG: Code 0 at +_ok)s,P+Z-#p\TRW:121262026
005076:0000 Hash check failed for file /BDMV/STREAM/00914.m2ts at offset 2225399808, file is corrupt.
005076:0000 Hash check failed for file /BDMV/STREAM/00914.m2ts at offset 2225596416, file is corrupt.
005076:0000 Hash check failed for file /BDMV/STREAM/00914.m2ts at offset 2225793024, file is corrupt.
005076:0000 Hash check failed for file /BDMV/STREAM/00914.m2ts at offset 2225989632, file is corrupt.
005076:0000 Hash check failed for file /BDMV/STREAM/00914.m2ts at offset 2226186240, file is corrupt.
005077:0000 Too many hash check errors in file /BDMV/STREAM/00914.m2ts.
005078:0000 Hash check for /BDMV/STREAM/00914.m2ts : 67.46% corrupt, 32.52% correct, 99.99% checked.
005079:0080 Backup done but 1 files failed hash check
005082:0404 Backup done but 1 files failed hash check.
Drive Information:
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-12B1ST
Revision: 1.03
Serial number: (I hid this)
Bus encryption flags: 1E
Highest AACS version: 43
Any suggestions on what I should do next?
Re: New BR disks - File is corrupt
#2 Post by Woodstock » Mon Mar 03, 2014 2:21 am
If you Open the disk instead of using Backup, and try saving the individual titles as MKV files, what results do you get?
GuruMeditation
#3 Post by GuruMeditation » Mon Mar 03, 2014 5:02 am
Same deal when trying to save from there or setup for stream. Log is full of debug messages like so:
004004:0000 The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 2202802176, attempting to work around
tp=PrVNOP8LMbu0PI4lHjshdQ6bc1z0O4N7YY0dtBlzUvn/fRbewIZjtSUPKgmJpuv/onVbjuIL5YpAZWQJyGk1krSJC+aJBEi/U7YBbim7NqQf9L2/YAJru1bH5j5M0QhH8noNtdNf3h+blYzQFZMB7K9uB6aQ3hW/nM0h7cDBcErwfqFpoRsufg0J2EUJ0T1kGxTGFGNI8ewych/EgnWP0RZ2IKbo6hGqmxrDMPJze/WKhavbrTeYjqidptO4=
001003:0020 DEBUG: Code 0 at ,QO;UTbH#WPlP$8&Xy4H:29394574
To try to figure this out I went back to one of my older bluray disks and loaded it in. It no longer works either and I suspect the other disks are the same. I then loaded makemkv onto the windows partition of this machine (which I hardly ever use). It now also is giving me the same problem. At least I have figured out it isn't the disks. Still stumped as to what it could be now though.
setarip_old
#4 Post by setarip_old » Tue Mar 11, 2014 6:37 pm
Hi!
Sounds like a drive problem - dirty or failing...
