Man of Steel dvd
mstg2000
Man of Steel dvd
Having a heck of a time with Man of Steel dvd.. when makemkv opens the disc, there's only 3 choices, and none of them are the movie. any thoughts?
Re: Man of Steel dvd
Enable debugging (link in my signature) and post what MakeMKV reports in the log when you open the disk. Should just be able to post it in a reply between CODE blocks...
jss42m
I'm having the same issue....
Log:
Debug log started at Mon Mar 10 12:55:47 2014 , written by MakeMKV v1.8.9 win(x64-release)
001005:0000 MakeMKV v1.8.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\james/MakeMKV_log.txt
Title skip vts=1 pgcn=1 hash=16C82F744703BD1E
003028:0000 Title #2 was added (1 cell(s), 0:00:07)
Title skip vts=1 pgcn=3 hash=4B9484C6A128768F
003028:0000 Title #4 was added (1 cell(s), 0:02:02)
003028:0000 Title #5 was added (2 cell(s), 0:06:34)
003028:0000 Title #6 was added (1 cell(s), 0:00:10)
003028:0000 Title #7 was added (4 cell(s), 0:05:40)
003029:0000 Audio stream #2 is identical to stream #1 and was skipped
003029:0000 Audio stream #3 is identical to stream #1 and was skipped
003029:0000 Audio stream #4 is identical to stream #1 and was skipped
003030:0000 Subtitle stream #6 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #7 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #8 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #9 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #10 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #11 is identical to stream #5 and was skipped
Application exited at Mon Mar 10 13:00:45 2014
Log:
