Man of Steel dvd
mstg2000
Man of Steel dvd
Post by mstg2000 » Sat Mar 01, 2014 7:51 am
Having a heck of a time with Man of Steel dvd.. when makemkv opens the disc, there's only 3 choices, and none of them are the movie. any thoughts?
Re: Man of Steel dvd
Post by Woodstock » Sun Mar 02, 2014 3:34 am
Enable debugging (link in my signature) and post what MakeMKV reports in the log when you open the disk. Should just be able to post it in a reply between CODE blocks...
jss42m
Post by jss42m » Mon Mar 10, 2014 1:04 pm
I'm having the same issue....
Log:
Debug log started at Mon Mar 10 12:55:47 2014 , written by MakeMKV v1.8.9 win(x64-release)
001005:0000 MakeMKV v1.8.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\james/MakeMKV_log.txt
Title skip vts=1 pgcn=1 hash=16C82F744703BD1E
003028:0000 Title #2 was added (1 cell(s), 0:00:07)
Title skip vts=1 pgcn=3 hash=4B9484C6A128768F
003028:0000 Title #4 was added (1 cell(s), 0:02:02)
003028:0000 Title #5 was added (2 cell(s), 0:06:34)
003028:0000 Title #6 was added (1 cell(s), 0:00:10)
003028:0000 Title #7 was added (4 cell(s), 0:05:40)
003029:0000 Audio stream #2 is identical to stream #1 and was skipped
003029:0000 Audio stream #3 is identical to stream #1 and was skipped
003029:0000 Audio stream #4 is identical to stream #1 and was skipped
003030:0000 Subtitle stream #6 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #7 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #8 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #9 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #10 is identical to stream #5 and was skipped
003030:0000 Subtitle stream #11 is identical to stream #5 and was skipped
Application exited at Mon Mar 10 13:00:45 2014
