Well, it's a definitely problem with converting BD. The matter is that i get a mkv with default audio track containing just a hiss. Switching in player second audio track corrects situation. I don't know, what i should post here besides m2ts properties, taking place in work. Let me know, please. What's about me, i guess it's something non standard with strange Audio PCM track.
General
Complete name : \BDMV\STREAM\00006.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 17.5 GiB
Duration : 1h 9mn
Overall bit rate : 36.3 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 1h 9mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : MBAFF
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Menu ID : 1 (0x1)
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Duration : 1h 9mn
Bit rate mode : Constant
Bit rate : 2 304 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 1.11 GiB (6%)
Audio #2
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA
Muxing mode : Stream extension
Duration : 1h 9mn
Bit rate mode : Variable
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Problems with BD Audio track
Sors mea Jesus!
- Contact:
Re: Problems with BD Audio track
The first tarack is LPCM audio track. Many players have problems playing mult-channel LPCM from matroska. What payer do you use?
It explain a problem. I've tried KMP, MPC and MediaPortal (ffdshow as decoder) It seems, that too many players doesn't know mkv+LPCM. Demux'em all
Sors mea Jesus!
