Feature Request: Max Length or Multiple Titles
When ripping many TV DVDs, there is often a play all title that is much longer. Currently, there is no way to tell makemkvcon to avoid this title or to list the titles you do want. This means that the overhead of rescanning the disc is necessary to pull the titles individually if using makemkvcon. Please consider adding maxlength in the same fashion as minlength or allowing us to specific multiple titles using makemkvcon.
Re: Feature Request: Max Length or Multiple Titles
I'd love to have this feature too. I think it will be a lot of work to accomplish this though but overall, I believe every user will be able to use this.
Mistakes are learning tools.
Again, plus 1! It would make automatic scripting of TV Show DVD's much easier and precise!
I just found makemkv, and this feature would really be appreciated.
Any possibility of this happening? Doesn't seem like it should be too hard.
joern.arne
+1 for the maxlength feature
would be really appreciated
- Contact:
You can do this using a new "manual DVD mode" - /manualdvd/
plittlefield
+1 yes please, the command line option would be fantastic!
--maxlength-
plittlefield
What news on this requested feature?
