Well, it's a definitely problem with converting BD. The matter is that i get a mkv with default audio track containing just a hiss. Switching in player second audio track corrects situation. I don't know, what i should post here besides m2ts properties, taking place in work. Let me know, please. What's about me, i guess it's something non standard with strange Audio PCM track.
General
Complete name                    : \BDMV\STREAM\00006.m2ts
Format                           : BDAV
Format/Info                      : Blu-ray Video
File size                        : 17.5 GiB
Duration                         : 1h 9mn
Overall bit rate                 : 36.3 Mbps
Maximum Overall bit rate         : 48.0 Mbps
Video
Menu ID                          : 1 (0x1)
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Duration                         : 1h 9mn
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 29.970 fps
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Scan type                        : MBAFF
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Menu ID                          : 1 (0x1)
Format                           : PCM
Format settings, Endianness      : Big
Format settings, Sign            : Signed
Muxing mode                      : Blu-ray
Duration                         : 1h 9mn
Bit rate mode                    : Constant
Bit rate                         : 2 304 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Resolution                       : 24 bits
Stream size                      : 1.11 GiB (6%)
Audio #2
Menu ID                          : 1 (0x1)
Format                           : DTS
Format/Info                      : Digital Theater Systems
Format profile                   : MA
Muxing mode                      : Stream extension
Duration                         : 1h 9mn
Bit rate mode                    : Variable
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Surround: L R, LFE
									Problems with BD Audio track
Sors mea Jesus!
 - Contact:
Re: Problems with BD Audio track
The first tarack is LPCM audio track. Many players have problems playing mult-channel LPCM from matroska. What payer do you use?
It explain a problem. I've tried KMP, MPC and MediaPortal (ffdshow as decoder) It seems, that too many players doesn't know mkv+LPCM. Demux'em all
									Sors mea Jesus!
