Hello all. Was wondering if there was a way to play BR discs natively inside XBMC similar to how Linux users can (http://bloggingabout.com/bluray-playbac ... linux.html) with a script. I would like to be able to play BR discs within XBMC by just popping in the disc and having it play right inside of XBMC without an external player like PowerDVD or Arcsoft.
Is this possible?
XBMC Script for Windows?
setarip_old
Re: XBMC Script for Windows?
Your question has nothing to do with MakeMKV and, therefore, should not have been posted to this forum...
adave
Sorry. I should have included that I'd like to do this with MakeMKV as the plug-in application. Regardless, it looks like its possible. If anyone is interested in being able to play BR discs in XBMC using MakeMKV, check out this post on the XBMC forum.
http://forum.xbmc.org/showthread.php?t= ... ht=windows
