Hello there,
anybody noticed that the Flag Option is missing since 1.8.8?
Its now impossible to mark a sound track or subtitle as Default, except the order weight.
Or im just blind?
Regards Agarwaen
1.8.8 - Missing Flag Options
- Contact:
Re: 1.8.8 - Missing Flag Options
Ouch. Another bug in 1.8.8 . Thanks for bringing to attention.Agarwaen wrote:anybody noticed that the Flag Option is missing since 1.8.8?
You are welcome!
I have just ripped 'The Kingdom' blu ray.
There are 4 sub streams, I've ripped the last one only which is the forced subs but it isn't the default sub track when I play in vlc.
Is this the reason why?
- Contact:
Yes, the default/forced logic is broken in 1.8.8 . You can change flags with mkvtoolnix header editor.
Does this mean the selection of "forced" subtitle when checked isn't catching the forced subtitle correctly?
- Contact:
No, it only means that "forced" flag will not be set in output MKV file. The actual track will be correct. Only flags placement is affected.Oscarboy1 wrote:Does this mean the selection of "forced" subtitle when checked isn't catching the forced subtitle correctly?
