DVDs from WND (World Net Daily)
bk7777
Post by bk7777 » Wed Feb 19, 2014 2:52 am
DVD's from WND (World Net Daily)
I just purchased 4 DVDs from WND and none of them will work under LINUX (Ubuntu / Mint 13 LTS) using version 1.8.8. Here is the log:
Saving 1 titles into directory /data3/blu-ray decrypt/MASADA_MYSTERY_DVD
DEBUG: Code 268614528 at W~xN~`Q&AWbYhjmsH5t.:213137160
DEBUG: Code 0 at W~xN~`Q&AWbYhjmsH5t.:121268972
DEBUG: Code 0 at @rLo\G"H'Uvr~5.:121263429
DEBUG: Code 1 at wQ!b\D1E )(unf\}.i:213131272
DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:121263084
LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:213132560
DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:29397794
DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:213135251
DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:121267914
Failed to save title 0 to file /data3/blu-ray decrypt/MASADA_MYSTERY_DVD/title00.mkv
0 titles saved, 1 failed
Now I also have mkmkv on a WIN 7 LT. and it worked on 2 DVDs. Have not had a chance to try the other 2 yet.
I am assuming the problem under LINUX is "LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available"
What do I need to do to correct?
Thanks,
Brian
Re: DVDs from WND (World Net Daily)
Post by Woodstock » Wed Feb 19, 2014 2:56 am
Yes, bug in 1.8.8. There is a topic on this subject in the General section, with what can be done about it until the next version comes out.
bk7777
Post by bk7777 » Wed Feb 19, 2014 3:26 am
Thanks for the update.... I thought I was using version 1.8.8 on the WIN 7 system and found out it was 1.7.6 and that version worked. Once I finally upgraded WIN 7 to 1.8.8 is broke as well.
OK looking forward to 1.8.9 with the fix.
Thanks,
Brian
