Ender's Game Bluray
Rydsen
Re: Ender's Game Bluray
Post by Rydsen » Wed Feb 12, 2014 4:36 am
Thanks. I just ripped all 4 titles that matched the run time reported. Then I skimmed through each of them and 815 is the only one that didn't have any repeats that I noticed so thank you for confirming that.
Loiosh
Post by Loiosh » Wed Feb 12, 2014 6:12 am
Welcome, guys.
Just watched it.... The book is better, but the movie is shiny :)
nickbuol
Post by nickbuol » Wed Feb 12, 2014 3:11 pm
Rydsen wrote:Thanks. I just ripped all 4 titles that matched the run time reported. Then I skimmed through each of them and 815 is the only one that didn't have any repeats that I noticed so thank you for confirming that.
Are you using the Redbox rental too like zaraknid?
Just trying to decode what is working for the different ones. I am going to rip 821 from the Target Steelbook (should be the same as the non-steel ones) tonight, but I won't be able to test it for a few days as I am helping my parents load a moving truck tonight and then I am driving it just over 1000 miles on Friday so I will need to try to prioritize other things until I get back late Sunday (at least I am flying home).
nickbuol
Post by nickbuol » Wed Feb 12, 2014 3:12 pm
Loiosh wrote:Welcome, guys.
I hear that it has some killer audio and LFE too. Can't wait!
hifiaudio3
Post by hifiaudio3 » Wed Feb 12, 2014 4:17 pm
Per another forum .815 is correct for the Redbox disc.
I am getting a very high audio skew on this disc (also my first time to use v 1.8.8 of the software). Is this normal? I have not seen audio skews longer than around 13-19 ms before, as dropping a frame would cut the skew down to at least that level, it seems. See below:
AV synchronization issues were found in file 'Z:/Movies/Ender's Game/Ender's Game.mkv' (title #162)
AV sync issue in stream 1 at 0:03:31.920 with duration of 15.958ms : encountered overlapping frame, audio skew is +15.958ms
AV sync issue in stream 1 at 0:03:53.650 with duration of 29.958ms : encountered overlapping frame, audio skew is +45.916ms
AV sync issue in stream 1 at 0:03:53.696 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +13.916ms
AV sync issue in stream 1 at 0:06:26.928 with duration of 1.875ms : encountered overlapping frame, audio skew is +15.791ms
AV sync issue in stream 1 at 0:06:56.582 with duration of 9.375ms : encountered overlapping frame, audio skew is +25.166ms
AV sync issue in stream 1 at 0:07:35.455 with duration of 7.833ms : encountered overlapping frame, audio skew is +33ms
AV sync issue in stream 1 at 0:07:35.488 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +1ms
AV sync issue in stream 1 at 0:10:06.314 with duration of 20.958ms : encountered overlapping frame, audio skew is +21.958ms
AV sync issue in stream 1 at 0:10:29.629 with duration of 13.041ms : encountered overlapping frame, audio skew is +35ms
AV sync issue in stream 1 at 0:10:29.664 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +3ms
AV sync issue in stream 1 at 0:11:08.376 with duration of 4.958ms : encountered overlapping frame, audio skew is +7.958ms
AV sync issue in stream 1 at 0:25:04.419 with duration of 20.458ms : encountered overlapping frame, audio skew is +28.416ms
AV sync issue in stream 1 at 0:25:26.566 with duration of 28.875ms : encountered overlapping frame, audio skew is +57.291ms
AV sync issue in stream 1 at 0:25:26.624 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +25.291ms
AV sync issue in stream 1 at 0:26:27.335 with duration of 30.958ms : encountered overlapping frame, audio skew is +56.25ms
AV sync issue in stream 1 at 0:26:27.392 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +24.25ms
AV sync issue in stream 1 at 0:49:11.990 with duration of 17.041ms : encountered overlapping frame, audio skew is +41.291ms
AV sync issue in stream 1 at 0:49:12.032 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +9.291ms
AV sync issue in stream 1 at 0:49:44.898 with duration of 20.125ms : encountered overlapping frame, audio skew is +29.416ms
AV sync issue in stream 1 at 0:50:08.338 with duration of 15.916ms : encountered overlapping frame, audio skew is +45.333ms
AV sync issue in stream 1 at 0:50:08.384 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +13.333ms
Forced subtitles track #2 turned out to be empty and was removed from output file
Forced subtitles track #3 turned out to be empty and was removed from output file
nickbuol
Post by nickbuol » Wed Feb 12, 2014 4:26 pm
Does this "other forum" mention anything for the retail disc?
EDIT: SlySoft forums are confirming 815 for Redbox and 821 for US retail as was listed previous, so that seems like enough confirmation for me to go 821... :D
seantnichols
Post by seantnichols » Wed Feb 12, 2014 9:04 pm
815 is the correct rental title, here is my quick tip for finding them.
After getting the exact runtime from a player (like TMT or a real player) I did a full backup of the disc. I found the 4 titles with the same runtime and typed out the segments like the OP did. I then browsed to the rip folder and just looked at the chunks in order, you can very quickly find the repeat segments without having to rip and and watch, by process of elimination I found 815. This all took about 10 minutes to complete.
I use this method for all movies like this, hopefully it helps the next person. :D
archer75
Post by archer75 » Fri Feb 14, 2014 4:00 am
815 doesn't seem to have an HD audio track?
Gronnie
Post by Gronnie » Fri Feb 14, 2014 6:30 am
Lionsgate usually cripples rental discs. Certainly doesn't make me want to run out and buy it....
Rydsen
Post by Rydsen » Fri Feb 14, 2014 10:46 pm
archer75 wrote:815 doesn't seem to have an HD audio track?
Gronnie is correct. It's sad but more and more studios are leaving off the HD audio tracks from the rental discs from Redbox and Netflix so you only get the lossy DD or DTS track. It's up to you to determine if it makes that much of a difference to buy the actual release just for the HD audio.
joe42
Post by joe42 » Fri Feb 14, 2014 10:57 pm
Don't blame just the studios. Netflix and RedBox are as much to blame as the studios. Netflix can buy retail blu-rays legally if they are willing to forgo the discount they get from the studios for the rental copies.
Rydsen
Post by Rydsen » Sat Feb 15, 2014 1:02 am
Fair enough, they're both equally to blame. Either way, it's unfortunate.
joe42
Post by joe42 » Sat Feb 15, 2014 2:04 am
I don't make the distinction just to be argumentative. There is little that can be done about the studios selling discounted rental copies. But if enough Netflix and Redbox customers complain about getting inferior discs, then Netflix and Redbox might stop shortchanging their customers and refuse to buy neutered discs.
jasrun2
Post by jasrun2 » Thu Feb 20, 2014 12:15 pm
Still working on this.... mt copy 815.mpls (t149) only has DTS 5.1, but correct sequence:
513, 501, 504, 510, 505, 502, 514, 507, 506, 508, 509, 503, 511, 515, 512
As suggested 821 (t164) looked right and has full audio tracks, but segments 506 and 511 are reversed. At 30 min, at the end of the eating scene, it jumps when Ender is playing the mind-video game. Otherwise is correct. Anyone have an idea if there is still another track with full audio and the correct sequencing? Thanks J
jhodgesatmb
Post by jhodgesatmb » Thu Feb 20, 2014 3:00 pm
You cannot skip through the movie and see the error. In MakeMKV I had many segments that had the same number of chapters so, stupidly, I encoded the first one (Ender's_Game_t01.mkv). When I watched it, there were two times when scenes were jumbled so that the order was incorrect. The first one is when he first plays the video game. The second one is when Graf first promotes him. I didn't see any others. I do not think you could tell with a fast forward but maybe.
