Segfault with some Blu-Rays
Markus
#1 Post by Markus » Wed Feb 05, 2014 3:12 pm
while trying to copy my collection I noticed issues with a few of the discs. Some of the disks copied fine (backup and mkv), others however, gave me a segfault while reading the disc info. Those are:
  • Eden of the East: Paradise Lost (UK)
  • Eden of the East: King of Eden (UK)
  • Puella Magi Madoka Magica (UK)
These discs play fine in VLC or XBMC. (Note: The Eden of the East Series (same box) copied fine.)
Debug log for Paradise Lost:
Debug log started at Wed Feb  5 14:51:40 2014 , written by MakeMKV v1.8.8 linux(x64-release)
001005:0000 MakeMKV v1.8.8 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/****/MakeMKV_log.txt
001009:0000 Profile parsing error: default profile missing, using builtin default
001003:0020 DEBUG: Code 0 at YD}xmQo(5ruv(/U^&,"K"KK:213130122
DAFD=PAAAADAAAAEABDQEEAAADAQ==
DCE=80l7ypywdj/fRMhIbOt+MjTlrCra8HtHId71piRZU7d7jj0Fu89WIaQAJSYShKVDeUiDLW29Xc5q3SnBIcYO0+TDoLsoQdE1p95ETndumU7PD99fWQwXSq8slwpKYdiHN+vtUHDm3yDQ2GyNOlfKFPIF/WIjswLIRw==
DISCID=59EAF7B6D8F009F0F7AE88902353438D39430153
003025:0000 Title #00000.mpls has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00040.mpls was added as title #0
003025:0000 Title #00002.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00019.mpls was added as title #1
003309:0000 Title 00018.mpls is equal to title 00040.mpls and was skipped
003307:0000 File 00008.mpls was added as title #2
003307:0000 File 00001.mpls was added as title #3
003025:0000 Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00047.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00046.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00032.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Segmentation fault
gdb says:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffd1de7700 (LWP 3147)]
__strlen_sse2_pminub () at ../sysdeps/x86_64/multiarch/strlen-sse2-pminub.S:38
38	../sysdeps/x86_64/multiarch/strlen-sse2-pminub.S: No such file or directory.
System is:
  • OS: Ubuntu 13.10 (Linux 3.11.0-15-generic #25-Ubuntu SMP x86_64 x86_64 x86_64 GNU/Linux)
  • Drive: LiteOn IHOS104
Do you need any further information?
Thank you for your help.
Re: Segfault with some Blu-Rays
#2 Post by mike admin » Thu Feb 06, 2014 8:17 am
Please capture the core file for the crash. /onlinehelp/dump.html
Markus
#3 Post by Markus » Thu Feb 06, 2014 11:49 am
Here you go: [file downloaded]
Markus
#4 Post by Markus » Fri Feb 14, 2014 3:58 pm
I just tried copying these Blu-Rays on Windows and it worked fine. So unless the problem is the SATA-Controller, it is specific to the Linux release.
Markus
#5 Post by Markus » Fri Feb 14, 2014 8:43 pm
Now that's weird... I just plugged the Blu-Ray drive back into my Linux-machine and suddenly everything works... no idea why. Both Eden of the East discs copied fine.
The only thing I noticed was that MakeMKV is putting out 2 errors:
005003:0000 Failed to save title 4 to file /home/****/Videos/DVD/BD/mkv/EOTE/Paradise Lost/title04.mkv
005003:0000 Failed to save title 18 to file /home/****/Videos/DVD/BD/mkv/EOTE/Paradise Lost/title18.mkv
005004:0080 17 titles saved, 2 failed
However, all important titles have been copied.
Full log:
Debug log started at Fri Feb 14 18:55:52 2014 , written by MakeMKV v1.8.8 linux(x64-release)
DCE=xWbFHgcvv88vyYUIM8uMkNEfqKp6zDWyEMB6GenQCw78SAn/QQHKyDcUA2l2n1d/HbvXfBv4F32Z/KgchS9COBvuL9crQXrcO/Q7ASSSWyauGSn6QaR6Mk4U4k1G03s9M7jf1aZ9m2QlV4B8Gtxg0LtPxf7uoI+ybg==
003307:0000 File 00000.mpls was added as title #0
003307:0000 File 00040.mpls was added as title #1
003307:0000 File 00002.mpls was added as title #2
003307:0000 File 00019.mpls was added as title #3
003307:0000 File 00008.mpls was added as title #4
003307:0000 File 00001.mpls was added as title #5
003025:0000 Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003307:0000 File 00026.m2ts was added as title #6
003307:0000 File 00025.m2ts was added as title #7
003307:0000 File 00024.m2ts was added as title #8
003307:0000 File 00023.m2ts was added as title #9
003307:0000 File 00022.m2ts was added as title #10
003307:0000 File 00021.m2ts was added as title #11
003307:0000 File 00020.m2ts was added as title #12
003307:0000 File 00019.m2ts was added as title #13
003307:0000 File 00016.m2ts was added as title #14
003307:0000 File 00015.m2ts was added as title #15
003025:0000 Title #00047.m2ts has length of 0 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003307:0000 File 00046.m2ts was added as title #16
003307:0000 File 00034.m2ts was added as title #17
003025:0000 Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 2 seconds and was therefore skipped
003307:0000 File 00001.m2ts was added as title #18
005014:0000 Saving 19 titles into directory /home/****/Videos/DVD/BD/mkv/EOTE/Paradise Lost
AV sync issues in /home/****/Videos/DVD/BD/mkv/EOTE/Paradise Lost/title00.mkv
AV sync in 1,2 at 0:00:56.056 (8ms) : encountered overlapping frame, audio skew is +8ms
004001:0000 Forced subtitles track #4 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #6 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #7 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #9 turned out to be empty and was removed from output file
THDSF: [truehd @ 0x7f4af80c3260] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af80c3260] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af80c3260] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af805a800] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af805a800] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af805a800] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af821aa60] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af821aa60] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af821aa60] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8612ea0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8612ea0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8612ea0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af86c4400] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af86c4400] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af86c4400] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af88bc080] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af88bc080] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af88bc080] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af87a6d60] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af87a6d60] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af87a6d60] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8556060] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8556060] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8556060] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af84a0e20] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af84a0e20] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af84a0e20] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8cb9200] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8cb9200] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8cb9200] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af80ef780] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af80ef780] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af80ef780] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8c1b280] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8c1b280] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8c1b280] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af806c500] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af806c500] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af806c500] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af866f760] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af866f760] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af866f760] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af866e8e0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af866e8e0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af866e8e0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af87479a0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af87479a0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af87479a0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8da8d80] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8da8d80] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8da8d80] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af82d94e0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af82d94e0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af82d94e0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af867db20] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af867db20] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af867db20] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8f9a3e0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8f9a3e0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8f9a3e0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af82d7180] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af82d7180] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af82d7180] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8ae40e0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8ae40e0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8ae40e0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af87e6e20] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af87e6e20] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af87e6e20] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8cfc6c0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8cfc6c0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8cfc6c0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8d52660] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8d52660] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8d52660] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af85f6c80] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af85f6c80] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af85f6c80] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af87532e0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af87532e0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af87532e0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8707b40] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8707b40] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8707b40] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af812d080] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af812d080] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af812d080] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8fae6c0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8fae6c0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8fae6c0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8680d40] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8680d40] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8680d40] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8be9fa0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8be9fa0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8be9fa0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8cd0260] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8cd0260] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8cd0260] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8d19da0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8d19da0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8d19da0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af84ac740] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af84ac740] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af84ac740] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af9247900] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af9247900] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af9247900] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af89dd400] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af89dd400] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af89dd400] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8a70d60] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8a70d60] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8a70d60] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8a60be0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8a60be0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8a60be0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af871bca0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af871bca0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af871bca0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af83872a0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af83872a0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af83872a0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8abfba0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8abfba0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8abfba0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8abc7c0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8abc7c0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8abc7c0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af87569e0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af87569e0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af87569e0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af812ba40] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af812ba40] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af812ba40] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af83dad60] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af83dad60] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af83dad60] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af827f1c0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af827f1c0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af827f1c0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8b98520] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8b98520] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8b98520] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af843d1a0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af843d1a0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af843d1a0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af84a3820] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af84a3820] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af84a3820] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af90245c0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af90245c0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af90245c0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8025b00] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8025b00] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8025b00] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af933df40] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af933df40] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af933df40] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8830ce0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8830ce0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8830ce0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8e56d00] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8e56d00] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8e56d00] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af822cfc0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af822cfc0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af822cfc0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8857c00] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8857c00] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8857c00] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af9154740] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af9154740] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af9154740] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8b62760] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8b62760] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8b62760] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8566bc0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8566bc0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8566bc0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af910b2e0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af910b2e0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af910b2e0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af910b140] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af910b140] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af910b140] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af846fbc0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af846fbc0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af846fbc0] Unsupported bit depth: 0
001003:0020 DEBUG: Code 268614528 at W~xN~`Q&AWbYhjmsH5t.:213137160
001003:0020 DEBUG: Code 0 at W~xN~`Q&AWbYhjmsH5t.:121268972
001003:0020 DEBUG: Code 0 at @rLo\G"H'Uvr~5.:121263429
001003:0020 DEBUG: Code 1 at wQ!b\D1E )(unf\}.i:213131272
001003:0020 DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:121263084
001002:0020 LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
001003:0020 DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:213132560
001003:0020 DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:29397794
001003:0020 DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:213135251
001003:0020 DEBUG: Code 0 at wQ!b\D1E )(unf\}.i:121267914
AV sync issues in /home/****/Videos/DVD/BD/mkv/EOTE/Paradise Lost/title05.mkv
AV sync in 2,4 at 1:32:07.563 (20.291ms) : encountered overlapping frame, audio skew is +20.291ms
THDSF: [truehd @ 0x7f4af8b29480] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8b29480] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8b29480] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8b29480] End of stream indicated.
004001:0000 Forced subtitles track #8 turned out to be empty and was removed from output file
AV sync in 2,4 at 1:32:17.573 (6ms) : encountered overlapping frame, audio skew is +26.291ms
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
THDSF: [truehd @ 0x7f4af85feb40] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af85feb40] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af85feb40] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af85feb40] End of stream indicated.
THDSF: [truehd @ 0x7f4af8c6f4e0] err{or,}_recognition separate: 1; 1
THDSF: [truehd @ 0x7f4af8c6f4e0] err{or,}_recognition combined: 1; 1
THDSF: [truehd @ 0x7f4af8c6f4e0] Unsupported bit depth: 0
THDSF: [truehd @ 0x7f4af8c6f4e0] End of stream indicated.
005037:0204 Copy complete. 17 titles saved, 2 failed.
Markus
#6 Post by Markus » Sat Feb 15, 2014 8:13 am
The Madoka Magica discs still fail, although differently. On these discs, 9 out of 9 titles fail (including the actual movie).
Maybe everything is related to the LPCM bug in 1.8.8, at least that seems to be the case with these discs. I'll try it now using 1.8.7.
PS: Yep it seems to be copying...
PPS: Discs copied fine. 1.8.7 also copied the two tracks from the Eden of the East BD.
Only a few of these error messages survived:
001003:0020 DEBUG: Code 2147483647 at O~qO!<$ef:]Uy7Z^:29393953
001003:0020 DEBUG: Code 2147483647 at 'nNZ+<% Sdwp%d|!mf:213132100
001003:0020 DEBUG: Code 2147483647 at 'nNZ+<% Sdwp%d|!mf:29393930
002003:0000 Error 'Posix error - Unknown error 1073741823' occurred while reading '/dev/sr0' at offset '622983168'
004007:0010 AV synchronization issues were found in file '/home/****/Videos/DVD/BD/mkv/EOTE/Paradise Lost/title04.mkv' (title #5)
004008:0010 AV sync issue in stream 1 at 0:01:51.170 with duration of 670ms : 134 overlapping frame(s) dropped at segment boundary
004008:0010 AV sync issue in stream 1 at 0:03:22.570 with duration of 221.666ms : audio gap - 44.333 missing frame(s)
#7 Post by mike admin » Sat Feb 22, 2014 7:55 am
Markus wrote:I just tried copying these Blu-Rays on Windows and it worked fine. So unless the problem is the SATA-Controller, it is specific to the Linux release.
It is specific to the way you installed it. makemkvcon expects to find profiles in ../share directory (relative to executable location) or in the MakeMKV data directory. The bug in 1.8.8 is that makemkvcon crashes if no single profile is available and blu-ray disc has picture metadata. The next version will have a fix, but I still suggest installing MakeMKV in a regular way.
And thanks a lot for sending the dump.
