Insanity Work out
NutFlush920
Insanity Work out
Post by NutFlush920 » Tue Feb 04, 2014 9:55 pm
I'm having a hell of a time making an MKV file of the primary work out on the Insanity AX CARDO CONDITIONING & CARDIO ABS disc. I've tried from multiple DVD/Bluray drives. Even tried an ISO of the disc made with AnyDVD Ripper (which worked without an issue). I get the same thing every time. I should note that out of the 13 disc set, this is the only title I'm having an issue with.
Any thoughts?
MakeMKV v1.8.8 darwin(x86-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRW GS31N TA17d" opened in OS access mode.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Title #1 was added (51 cell(s), 0:56:58)
Title #2 was added (33 cell(s), 0:22:30)
Title #3 has length of 70 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/Mac Files/Video/Rips/MKV/
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790466048, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790468096, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790470144, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790472192, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790474240, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790476288, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790478336, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790480384, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790482432, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790484480, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790486528, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790488576, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790490624, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790492672, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790494720, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790496768, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790498816, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790500864, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790502912, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790504960, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790507008, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790509056, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790511104, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790513152, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790515200, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790517248, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790519296, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790521344, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790523392, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790525440, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790527488, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790529536, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790531584, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790533632, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790535680, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790537728, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790539776, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790541824, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790543872, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790545920, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790547968, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790550016, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790552064, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790554112, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790556160, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790558208, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790560256, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790562304, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790564352, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790566400, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790568448, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790570496, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790572544, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790574592, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790576640, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790578688, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790580736, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790582784, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790584832, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790586880, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790588928, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790590976, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790593024, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790595072, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790597120, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790599168, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790601216, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790603264, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790605312, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790607360, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790609408, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790611456, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790613504, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790615552, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 1790617600, attempting to work around
Failed to save title 0 to file /Volumes/Mac Files/Video/Rips/MKV//title00.mkv
0 titles saved, 1 failed
NutFlush920
Re: Insanity Work out
Post by NutFlush920 » Sat Feb 08, 2014 11:56 am
Anyone?
Post by Woodstock » Sat Feb 08, 2014 10:50 pm
The work-arounds that MakeMKV is trying aren't managing to get past the problem in the VOB file. It is quite likely that Mike will want you to follow the procedures found here:
http://www.makemkv.com/onlinehelp/testdump.html
NutFlush920
Post by NutFlush920 » Sun Feb 09, 2014 1:46 pm
I can easily do this if Mike would like.
NutFlush920
Post by NutFlush920 » Sun Feb 09, 2014 2:59 pm
Sent
Post by mike admin » Fri Feb 14, 2014 9:54 am
Will be fixed in the next version. But overall, the video on the disc is very broken.
NutFlush920
Post by NutFlush920 » Fri Feb 14, 2014 3:24 pm
Thanks Mike.
NutFlush920
Post by NutFlush920 » Wed Feb 26, 2014 10:11 pm
I just upgraded to the latest version of MakeMKV and now get "Failed to open disc". I tried on both my Mac and Windows 7 PC.
Any thoughts?
NutFlush920
Post by NutFlush920 » Wed Feb 26, 2014 10:37 pm
On a side note, I just tried it though DVDFab trial and it worked fine. The file however has the DVDFab.com watermark since I didn't pay for it. I hope Mike can get MakeMKV to work. This is the only workout of the set that doesn't convert.
