problem with HD-DVDs
I've got a lot of unencrypted ISOs on a network drive that I mount with Virtual Clone Drive. I've been converting them so I can watch with VLC. I can convert Blu-Rays from there without trouble. But the several HD-DVDs I've tried all fail within approximately 30 seconds of clicking Make MKV button with:
MakeMKV v1.8.7 win(x64-release) started
AACS directory not present, assuming unencrypted disc
Saving 1 titles into directory E:/MadeMKVs
Failed to save title 0 to file E:/MadeMKVs/_t00.mkv
0 titles saved, 1 failed
Smithcraft
Re: problem with HD-DVDs
Please consider turning on the debugging messages in the preferences, and try to scan again, and post that log.
SC
SC
Here you go:
Debug logging enabled, log will be saved as C:\Users\Turgon/MakeMKV_log.txt
DEBUG: Code 0 at |v8pAS,=n~vb~)-O;:121262164
DEBUG: Code 0 at N(!LLW.xM"Hl!e)}P$\:29396299
Saving 1 titles into directory E:/MadeMKVs <--- sits here for about 40 seconds then fails
DEBUG: Code 0 at ^k(h-AvkRp`%^bzDr4_:121263820
DEBUG: Code 0 at AsEg3|1vZX"LU'8]?q}N:121262739
DEBUG: Code 0 at l1;{3&6hr=C{IiB}Air:121261681
DEBUG: Code 0 at AsEg3|1vZX"LU'8]?q}N:213130743
DEBUG: Code 62153 at AsEg3|1vZX"LU'8]?q}N:29393332
DEBUG: Code 0 at IY2v.p;V.7|,gSWb@a:nd:29398622
Failed to save title 0 to file E:/MadeMKVs/Feature_Presentation_t00.mkv
The mounted ISO does play in an ancient version of PowerDVD.
- Contact:
looks like a very broken ISO. Please try:
1 - opening the ISO file itself instead of mounted image from MakeMKV (file->Open)
2 - if (1) fails, try extracting all files from ISO to a folder and open the files with MakeMKV.
I'll give it a shot.
This happens with all HD-DVDs backups I've tried so far, so perhaps something hosed about the way they were created. Though, they do play fine in old version of Power-DVD.
#1 fails with same error. Will try #2 now.
Extracting the files to a folder and attempting to open them (either HVA00001.VTI or DISCID.DAT) with MakeMKV resulted in a sub-set of the same errors:
DEBUG: Code 0 at AsEg3|1vZX"LU'8]?q}N:121262762
DEBUG: Code 57290 at AsEg3|1vZX"LU'8]?q}N:29393332
Why would this play in Power DVD and not convert with MKV?
Are there alternatives?
- Contact:
The EVO files are encrypted but AACS directory not present, plus few MAP files are missing. This is a very damaged rip - you'll have to use the original disc.
Well, the files are NOT encrypted. They play fine in Power DVD 7.
- Contact:
Maybe they are not, but they surely are marked as encrypted.jurld wrote:Well, the files are NOT encrypted. They play fine in Power DVD 7.
Is this set in a header somewhere? Might I be able to hex-edit the ISO to clear that tag?
