Debug log started at Tue Feb 11 13:46:40 2014 , written by MakeMKV v1.8.8 win(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.8.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Matt/MakeMKV_log.txt
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQkEHwEBAQ==
DCE=UFBQUFBiGRHRt8IsxvlvHRjbTkNJ+g9iLA5n1M5IZPzA0Xe3+95MTzhhMAwLBsJu3/QpD+grYu+6HY3j2w+Fb+PTNC6g/KzmFWexeJufsSxGZjdEPBrrwdpJQ0qMvO+KI9t1duFarxtkdBokqnX9Fjh8a0scN8US1w==
DCE=UFBQUFBiGRHRlOA7vpMVKshyIRACUF1H/4zJ1VpIZPzA0Xe3+95MTzhhMAwLBsJu3/QpD+grYu+6HY3j2w+Fb+PTNC6g/KzmFWexeJufsSxGZjdEPBrrwdpJQ0qMvO+KI9t1duFarxtkdBokqnX9Fjh8a0scN8US1w==
DISCID=DDC962F57ADFACEDA5E3020E0EC0131338B099F3
003025:0000 Title #00013.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #0
003307:0000 File 00300.mpls was added as title #1
003025:0000 Title #00000.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00020.mpls was added as title #2
003025:0000 Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00191.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50355.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 50357.m2ts was added as title #3
003025:0000 Title #50358.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50361.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50359.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50362.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 50360.m2ts was added as title #4
003025:0000 Title #50363.m2ts has length of 88 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50366.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50367.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50368.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50369.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50370.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50371.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50372.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50373.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50374.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50375.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50376.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50377.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50378.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50379.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50380.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #50381.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at rCslHZcacfad8SqwYp2XKTsx:0
001003:0020 DEBUG: Code 233 at z1Ali5kfFsPhcehsLdZ5SVZP:0
001003:0020 DEBUG: Code 233 at ZvQiaDOEjouReDDLz5Ok8FVw:0
001003:0020 DEBUG: Code 233 at LzGRD4t9SkByaOaUv4SXKKRM:0
001003:0020 DEBUG: Code 233 at FJDkU4T02UOO8OFHwukLm5Bk:0
001003:0020 DEBUG: Code 233 at jLnntSIe+0wzxWO6tRYcIK6n:0
001003:0020 DEBUG: Code 233 at tLqHOLWavV1WkS6lzZQZogEg:0
001003:0020 DEBUG: Code 233 at Ax5OICp1Bv01JheT0/rtcylr:0
001003:0020 DEBUG: Code 233 at kHkZqhwkOOTupLua19MyLIxd:0
001003:0020 DEBUG: Code 233 at FUXZ6m1eF5YBdy/V6OjxNngb:0
005014:0000 Saving 1 titles into directory C:/Users/Matt/Videos
001003:0020 DEBUG: Code 3221225488 at m_c/^{=H9JG<"15HuR07C,q$;:121263521
001003:0020 DEBUG: Code 3221225488 at 4}&wpbd5Zr{S0Y`,:29393953
001003:0020 DEBUG: Code 2 at h>],P[s5:P^nIwLz:213137827
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00023.m2ts' at offset '4391368704'
001003:0020 DEBUG: Code 3221225492 at m_c/^{=H9JG<"15HuR07C,q$;:121263521
001003:0020 DEBUG: Code 3221225492 at 4}&wpbd5Zr{S0Y`,:29393953
The Deadly Game blu-ray
matt198t
Re: The Deadly Game blu-ray
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00023.m2ts' at offset '5111672832'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00023.m2ts' at offset '5111672832'
001003:0020 DEBUG: Code 0 at m<9D`:#>*:$rD:*L;9*-:121262739
001003:0020 DEBUG: Code 0 at z}e&F5Qs!nNn/0&%5uY1:121261888
001003:0020 DEBUG: Code 0 at m<9D`:#>*:$rD:*L;9*-:213130743
001003:0020 DEBUG: Code 2495934 at m<9D`:#>*:$rD:*L;9*-:29393332
001003:0020 DEBUG: Code 0 at gT/uByVlkaW(A%vY$eM~;:121266810
001003:0020 DEBUG: Code 0 at 1,Qw9]%N`[[VSW.0`2X:29396276
RH2=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
FS ID=V_MPEG4/ISO/AVC C=1
TI=ZeNpjZICAH3fLHRgZCAOF3cEOILoVyo/JrwDrI0YvspoGdgYGCxYEfSCWgeElMwMDE0RaAKYWAEjoCao=
C_00000=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
matt198t
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
matt198t
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
001003:0020 DEBUG: Code 0 at *ZJ/Q/t|Z1=<{J|H=:121263728
001003:0020 DEBUG: Code 0 at *ZJ/Q/t|Z1=<{J|H=:121263176
001003:0020 DEBUG: Code 0 at *ZJ/Q/t|Z1=<{J|H=:29393930
005003:0000 Failed to save title 0 to file C:/Users/Matt/Videos/The_Deadly_Game_t00.mkv
005004:0080 0 titles saved, 1 failed
matt198t
2 discs both have same problem. The read rate slows down to kb/s
matt198t
Backing up disc into folder "D:\/backup/THE_DEADLY_GAME"
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00023.m2ts' at offset '3121283072'
DEBUG: Code 0 at e(GW}CZOu1/X?A|AU_zY:121269478
DEBUG: Code 0 at e(GW}CZOu1/X?A|AU_zY:213144129
Backup failed
Backup failed
/faq/item/7/catid/6matt198t wrote:Backing up disc into folder "D:\/backup/THE_DEADLY_GAME"
Backup failed
taseldor
Thanks! I'd been having that problem with another disc, brand-new, straight out of the shrink wrap, with no visible damage, and increasing the read retry count seems to have done the trick.
