Metallica Through the Never problem
syztemlord
Post by syztemlord »
I'm trying to rip the 2nd disc of the 3D bluray and I'm getting the following errors.
Debug log started at Wed Feb 12 17:07:41 2014 , written by MakeMKV v1.8.8 win(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.8.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Wozza/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQEEEgADAQ==
DCE=MnxmQ3DnuV3Q1dhnBIcNmXlj7QWNZfFv3NQv+TR6DaKe6s4gd2BH9jjwGbsEMUKjvEt0QoO79hCHcOyelyhC1ILtTrhUhXcunu//4JLxq+aNCD2YjIb6xTwipzhhpkOmLD3j/lwdcBnmKobLZkf64QjWSYclD5yq/A==
DCE=PijtSnNmBl2lOYNFKoCt3Gnr3tl6BrC+7j0iCN439yOcH6USGjV5QHFcDIM5y2fUd4qLXR8E1US3T6RN/3JjYaQPuuKT24JOQOdRYPkWaHahkkUSKTesbZLKMGMscKKjPGxEKsMFhbglH+4wZhF8kWLsaa2Jfmog+Q==
DISCID=651FCC7AF68C934E7F9086BD91DF9D703A83538F
003307:0000 File 00014.mpls was added as title #0
003307:0000 File 00086.mpls was added as title #1
003307:0000 File 00089.mpls was added as title #2
003307:0000 File 00090.mpls was added as title #3
003307:0000 File 00025.mpls was added as title #4
003309:0000 Title 00026.mpls is equal to title 00014.mpls and was skipped
003309:0000 Title 00069.mpls is equal to title 00089.mpls and was skipped
003309:0000 Title 00070.mpls is equal to title 00086.mpls and was skipped
003309:0000 Title 00071.mpls is equal to title 00090.mpls and was skipped
003025:0000 Title #00005.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00046.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00064.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00100.m2ts has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00101.m2ts was added as title #5
003307:0000 File 00102.m2ts was added as title #6
003307:0000 File 00103.m2ts was added as title #7
003025:0000 Title #00104.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 7 titles into directory F:/Movie Rips
001003:0020 DEBUG: Code 402832256 at aU6O@0b|?Id}aL<Q,Sm.:213137160
001003:0020 DEBUG: Code 0 at aU6O@0b|?Id}aL<Q,Sm.:121268972
001003:0020 DEBUG: Code 0 at juE@~sQm5j .>lx:121263429
001003:0020 DEBUG: Code 1 at Ke"dTt{1X]=2a,;;P]:213131272
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:121263084
001002:0020 LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:213132560
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:29397794
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:213135251
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:121267914
005003:0000 Failed to save title 1 to file F:/Movie Rips/METALLICA_Through_The_Never_Disc_2_t01.mkv
005003:0000 Failed to save title 2 to file F:/Movie Rips/METALLICA_Through_The_Never_Disc_2_t02.mkv
005003:0000 Failed to save title 3 to file F:/Movie Rips/METALLICA_Through_The_Never_Disc_2_t03.mkv
001003:0020 DEBUG: Code 268614528 at aU6O@0b|?Id}aL<Q,Sm.:213137160
005003:0000 Failed to save title 4 to file F:/Movie Rips/METALLICA_Through_The_Never_Disc_2_t04.mkv
005003:0000 Failed to save title 5 to file F:/Movie Rips/METALLICA_Through_The_Never_Disc_2_t05.mkv
005003:0000 Failed to save title 6 to file F:/Movie Rips/METALLICA_Through_The_Never_Disc_2_t06.mkv
005003:0000 Failed to save title 7 to file F:/Movie Rips/METALLICA_Through_The_Never_Disc_2_t07.mkv
005004:0080 0 titles saved, 7 failed
005037:0204 Copy complete. 0 titles saved, 7 failed.
Application exited at Wed Feb 12 17:10:54 2014
Any ideas?
Re: Metallica Through the Never problem
There is a bug in 1.8.8 that affects this. See http://makemkv.com/forum2/viewtopic.php?f=1&t=7551 in the General section.
syztemlord
Great, thank you :)
LarsUlrich
Post by LarsUlrich »
Just like I told Shawn concerning my music, I don't appreciate what you're doing to my Blu-ray.
