Handbrake not showing 7.1
diggler
Post by diggler »
I run the program and these are my audio options: 2 unknown (DTS-HD MA)(5.1) If I use RipBot264 DTS-HD MA 7.1 is available.
Sorry if posted in wrong section.
Romansh
Re: Handbrake not showing 7.1
Post by Romansh »
HandBrake only decodes he DTS core. Not a MakeMKV issue.
kevmitch
Post by kevmitch »
If you want the 7.1, you need to have makemkv decode to flac first. You could also use eac3to, or the mmdtsdec bundled with makemkv. All of these options however require you to supply dtsdecoderdll.dll from Arcsooft Total Media Theatre. There is currently no other sure way to fully decode DTS-HD MA.
