Failed to save title
Twowit2woo
#1 Post by Twowit2woo » Fri Feb 07, 2014 7:57 pm
No error - just failed to save title?
Cleaned the disc etc but noted no specific error.
Any help appreciated
MakeMKV v1.8.8 win(x64-release) started
Title #00007.mpls has length of 20 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00004.mpls has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
File 00000.mpls was added as title #0
File 00003.mpls was added as title #1
Title #00005.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00009.m2ts has length of 23 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00012.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00013.m2ts has length of 29 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00006.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Saving 2 titles into directory C:/atemp/01 - Dump/Bluray/Michael
Failed to save title 0 to file C:/atemp/01 - Dump/Bluray/Michael/title00.mkv
Forced subtitles track #3 turned out to be empty and was removed from output file
1 titles saved, 1 failed
Twowit2woo
Re: Failed to save title
#2 Post by Twowit2woo » Fri Feb 07, 2014 8:04 pm
I've just had the exact same thing on another disc too.
Discs are Blu-rays of an English comedian called Michael McIntyre. Here's the other one
Title #00008.mpls has length of 20 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00007.mpls has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
File 00001.mpls was added as title #0
File 00000.mpls was added as title #2
Title #00006.mpls has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00005.mpls has length of 9 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00007.m2ts has length of 24 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
File 00002.m2ts was added as title #3
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Saving 4 titles into directory C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime
Failed to save title 0 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t00.mkv
Failed to save title 1 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t01.mkv
Failed to save title 2 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t02.mkv
Failed to save title 3 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t03.mkv
0 titles saved, 4 failed
#3 Post by Woodstock » Fri Feb 07, 2014 8:35 pm
Have you enabled debug logging? If so, you'll see a message like this on start-up:
Debug logging enabled, log will be saved as C:\Users\jeffb/MakeMKV_log.txt
When debug logging is turned on, you will see more status messages, and the file generated will have more information on the state of the rip.
Twowit2woo
#4 Post by Twowit2woo » Sat Feb 08, 2014 8:54 am
Here we are :)
Debug log started at Sat Feb 08 08:52:09 2014 , written by MakeMKV v1.8.8 win(x64-release)
001005:0000 MakeMKV v1.8.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Paul/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQEEEgADAQ==
DCE=eK5soV2Ye3WPlREmauXe3RCwZeoqrXGEtqQIL8qPy3maSMe25QWZKuTcqJL+kvWcgF1Dh/pMx71Ll72UJjxuPIWsMZuVVvq1sCiYHu4YUIjc4nAAXJCVsn352rNnLfXtnJrYSkp3IzJPrXLjOg6XnJMQoS8iadrYhQ==
DCE=7kybbBXKEETsrXh8IRm+T9b0Embqi+fl016rb41Lr71tcAaMYpB55FhF0F1HF9AkYxQ/LcznMD5bWJxwPZXshnqJ1YojMWvKAQM7V9i8TFcW51+mbXBY+0QWXmrrriXxJ9cO8mF45VeU1LjHfstv8O6GwRI/27vM5A==
DISCID=D33C5A4D1FD5CC53D9C60636B7C1DCF0FD35C0EF
003025:0000 Title #00008.mpls has length of 20 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00007.mpls has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00003.mpls was added as title #1
003307:0000 File 00000.mpls was added as title #2
003025:0000 Title #00006.mpls has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00005.mpls has length of 9 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 24 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00002.m2ts was added as title #3
003025:0000 Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
005014:0000 Saving 4 titles into directory C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime
001003:0020 DEBUG: Code 402832256 at aU6O@0b|?Id}aL<Q,Sm.:213137160
001003:0020 DEBUG: Code 0 at aU6O@0b|?Id}aL<Q,Sm.:121268972
001003:0020 DEBUG: Code 0 at juE@~sQm5j .>lx:121263429
001003:0020 DEBUG: Code 1 at Ke"dTt{1X]=2a,;;P]:213131272
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:121263084
001002:0020 LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:213132560
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:29397794
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:213135251
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:121267914
005003:0000 Failed to save title 0 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t00.mkv
005003:0000 Failed to save title 1 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t01.mkv
001003:0020 DEBUG: Code 268614528 at aU6O@0b|?Id}aL<Q,Sm.:213137160
005003:0000 Failed to save title 2 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t02.mkv
005003:0000 Failed to save title 3 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t03.mkv
005004:0080 0 titles saved, 4 failed
005037:0204 Copy complete. 0 titles saved, 4 failed.
Application exited at Sat Feb 08 08:53:51 2014
#5 Post by Woodstock » Sat Feb 08, 2014 10:47 pm
Bug in 1.8.8. Mike knows about it. See http://www.makemkv.com/forum2/viewtopic.php?f=1&t=7551
Twowit2woo
#6 Post by Twowit2woo » Sun Feb 09, 2014 9:57 am
Thank you! :)
