Failed to save title
Twowit2woo
Post by Twowit2woo »
No error - just failed to save title?
Cleaned the disc etc but noted no specific error.
Any help appreciated
MakeMKV v1.8.8 win(x64-release) started
Title #00007.mpls has length of 20 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00004.mpls has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
File 00000.mpls was added as title #0
File 00003.mpls was added as title #1
Title #00005.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00009.m2ts has length of 23 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00012.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00013.m2ts has length of 29 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00006.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Saving 2 titles into directory C:/atemp/01 - Dump/Bluray/Michael
Failed to save title 0 to file C:/atemp/01 - Dump/Bluray/Michael/title00.mkv
Forced subtitles track #3 turned out to be empty and was removed from output file
1 titles saved, 1 failed
Twowit2woo
Re: Failed to save title
I've just had the exact same thing on another disc too.
Discs are Blu-rays of an English comedian called Michael McIntyre. Here's the other one
Title #00008.mpls has length of 20 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00007.mpls has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
File 00001.mpls was added as title #0
File 00000.mpls was added as title #2
Title #00006.mpls has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00005.mpls has length of 9 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00007.m2ts has length of 24 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
File 00002.m2ts was added as title #3
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
Saving 4 titles into directory C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime
Failed to save title 0 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t00.mkv
Failed to save title 1 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t01.mkv
Failed to save title 2 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t02.mkv
Failed to save title 3 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t03.mkv
0 titles saved, 4 failed
Have you enabled debug logging? If so, you'll see a message like this on start-up:
Debug logging enabled, log will be saved as C:\Users\jeffb/MakeMKV_log.txt
When debug logging is turned on, you will see more status messages, and the file generated will have more information on the state of the rip.
Twowit2woo
Here we are :)
Debug log started at Sat Feb 08 08:52:09 2014 , written by MakeMKV v1.8.8 win(x64-release)
001005:0000 MakeMKV v1.8.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Paul/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQEEEgADAQ==
DCE=eK5soV2Ye3WPlREmauXe3RCwZeoqrXGEtqQIL8qPy3maSMe25QWZKuTcqJL+kvWcgF1Dh/pMx71Ll72UJjxuPIWsMZuVVvq1sCiYHu4YUIjc4nAAXJCVsn352rNnLfXtnJrYSkp3IzJPrXLjOg6XnJMQoS8iadrYhQ==
DCE=7kybbBXKEETsrXh8IRm+T9b0Embqi+fl016rb41Lr71tcAaMYpB55FhF0F1HF9AkYxQ/LcznMD5bWJxwPZXshnqJ1YojMWvKAQM7V9i8TFcW51+mbXBY+0QWXmrrriXxJ9cO8mF45VeU1LjHfstv8O6GwRI/27vM5A==
DISCID=D33C5A4D1FD5CC53D9C60636B7C1DCF0FD35C0EF
003025:0000 Title #00008.mpls has length of 20 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00007.mpls has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00003.mpls was added as title #1
003307:0000 File 00000.mpls was added as title #2
003025:0000 Title #00006.mpls has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00005.mpls has length of 9 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 8 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 24 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00002.m2ts was added as title #3
003025:0000 Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
005014:0000 Saving 4 titles into directory C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime
001003:0020 DEBUG: Code 402832256 at aU6O@0b|?Id}aL<Q,Sm.:213137160
001003:0020 DEBUG: Code 0 at aU6O@0b|?Id}aL<Q,Sm.:121268972
001003:0020 DEBUG: Code 0 at juE@~sQm5j .>lx:121263429
001003:0020 DEBUG: Code 1 at Ke"dTt{1X]=2a,;;P]:213131272
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:121263084
001002:0020 LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:213132560
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:29397794
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:213135251
001003:0020 DEBUG: Code 0 at Ke"dTt{1X]=2a,;;P]:121267914
005003:0000 Failed to save title 0 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t00.mkv
005003:0000 Failed to save title 1 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t01.mkv
001003:0020 DEBUG: Code 268614528 at aU6O@0b|?Id}aL<Q,Sm.:213137160
005003:0000 Failed to save title 2 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t02.mkv
005003:0000 Failed to save title 3 to file C:/atemp/01 - Dump/Bluray/Michael/2012 - Showtime/Michael_McIntyre_Showtime_t03.mkv
005004:0080 0 titles saved, 4 failed
005037:0204 Copy complete. 0 titles saved, 4 failed.
Application exited at Sat Feb 08 08:53:51 2014
Bug in 1.8.8. Mike knows about it. See http://www.makemkv.com/forum2/viewtopic.php?f=1&t=7551
Twowit2woo
Thank you! :)
