3D output for Plex
tcoble33
3D output for Plex
#1 Post by tcoble33 » Sun Feb 02, 2014 9:23 pm
I'm sure this has been covered, but my searches have come up empty, so here goes...
I'm attempting to use MakeMKV to rip 3D blu-ray discs, and I need the output to be in a format that will allow me to watch the movies in 3D via Plex Home Theater. So far I've tried ripping just the main movie file, then applying the naming convention that Plex requires. (i.e., adding "Half-SBS" or "H-SBS" to the filename.) However, Plex plays this as a normal 2D movie. Any ideas on what I might be doing wrong?
I suspect that the issue may be that MakeMKV doesn't output the movie in the SBS format that Plex is looking for. If that's the issue, is there a solution? Alternately (for those who may also be Plex-savvy), is there a way to get Plex to recognize and play whatever format MakeMKV produces by default?
Thanks in advance for any recommendations!
Romansh
Re: 3D output for Plex
#2 Post by Romansh » Thu Feb 06, 2014 10:29 pm
Plex doesn't have an MVC (Blu-ray 3D) decoder, as libavcodec doesn't have one. This could maybe work via hardware-accelerated decoding, but you should ask on the Plex support forum, not here.
tcoble33
#3 Post by tcoble33 » Fri Feb 07, 2014 12:54 pm
Thanks, this confirms my understanding of the situation. That being the case, is Make MKV capable of outputting H-SBS or other non-MVC formats?
Romansh
#4 Post by Romansh » Fri Feb 07, 2014 8:59 pm
No. Before anything like this would be done, MakeMKV developers would have to write, integrate or otherwise license both an MVC decoder and an AVC encoder.
Not to mention since video re-encoding is involved, it would take forever if you want non-crappy output.
