Debug log started at Wed Jan 29 02:46:16 2014 , written by MakeMKV v1.8.7 win(x64-release)
001005:0000 MakeMKV v1.8.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\jeffb/MakeMKV_log_1.txt
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=QGRJ04pS35MfHZlzvvXOLTQDfK+ygJrLqIASs3MBSEEU9R8Raunz9OhbLypYhxD85yaeoMtoXhiWQo4RgwoIm89HQrjA0gnnvWtOv2po4rTDf361uxqSHzqjfBDm0SFC9KrwVGZEU2ZcasHvXXReZdMkrSPNm7Rtqw==
DISCID=F06CD7DF2B7B4B68CDFE71D9A720B9C4259237CA
003307:0000 File 00013.mpls was added as title #0
003307:0000 File 00010.mpls was added as title #1
003307:0000 File 00012.mpls was added as title #2
003307:0000 File 00011.mpls was added as title #3
003307:0000 File 00008.mpls was added as title #4
003307:0000 File 00009.mpls was added as title #5
003307:0000 File 00016.mpls was added as title #6
003307:0000 File 00014.mpls was added as title #7
003307:0000 File 00015.mpls was added as title #8
003307:0000 File 00025.m2ts was added as title #9
003307:0000 File 00024.m2ts was added as title #10
003307:0000 File 00023.m2ts was added as title #11
003307:0000 File 00022.m2ts was added as title #12
003307:0000 File 00021.m2ts was added as title #13
003307:0000 File 00020.m2ts was added as title #14
003307:0000 File 00017.m2ts was added as title #15
003025:0000 Title #00005.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00003.m2ts was added as title #16
003025:0000 Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00019.m2ts was added as title #17
003307:0000 File 00018.m2ts was added as title #18
It is not something that happens on a lot of titles (maybe 20-30%), but, when it happens on 1 disk of a set, it will happen on every disk in that set.
What information would you need from me to help track down why it is deciding to assign the title numbers out of order?
