1.8.8 - Missing Flag Options
Agarwaen
#1 Post by Agarwaen » Wed Feb 05, 2014 1:10 pm
Hello there,
anybody noticed that the Flag Option is missing since 1.8.8?
Its now impossible to mark a sound track or subtitle as Default, except the order weight.
Or im just blind?
Regards Agarwaen
Re: 1.8.8 - Missing Flag Options
#2 Post by mike admin » Thu Feb 06, 2014 8:10 am
Agarwaen wrote:anybody noticed that the Flag Option is missing since 1.8.8?
Ouch. Another bug in 1.8.8 . Thanks for bringing to attention.
Agarwaen
#3 Post by Agarwaen » Thu Feb 06, 2014 12:39 pm
You are welcome! :)
matt198t
#4 Post by matt198t » Thu Feb 06, 2014 1:51 pm
I have just ripped 'The Kingdom' blu ray.
There are 4 sub streams, I've ripped the last one only which is the forced subs but it isn't the default sub track when I play in vlc.
Is this the reason why?
#5 Post by mike admin » Fri Feb 14, 2014 9:38 am
Yes, the default/forced logic is broken in 1.8.8 . You can change flags with mkvtoolnix header editor.
Oscarboy1
#6 Post by Oscarboy1 » Fri Feb 14, 2014 6:46 pm
Does this mean the selection of "forced" subtitle when checked isn't catching the forced subtitle correctly?
#7 Post by mike admin » Wed Feb 19, 2014 7:41 am
Oscarboy1 wrote:Does this mean the selection of "forced" subtitle when checked isn't catching the forced subtitle correctly?
No, it only means that "forced" flag will not be set in output MKV file. The actual track will be correct. Only flags placement is affected.
