Error ripping disc created with Vegas Pro 12
Speedviktm
Post by Speedviktm » Tue Feb 04, 2014 4:06 pm
MakeMKV v1.8.8 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Doug/MakeMKV_log.txt
AACS directory not present, assuming unencrypted disc
File 00001.mpls was added as title #0
Title #00000.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Rips/MakeMKV
DEBUG: Code 402832256 at X\<GHV9%hv#|>M9`j%w":213137160
DEBUG: Code 0 at X\<GHV9%hv#|>M9`j%w":121268972
DEBUG: Code 0 at 30JU:?DhC`<]%,<:121263429
DEBUG: Code 1 at T\]8`),IY9.8H2il'F:213131272
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:121263084
LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:213132560
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:29397794
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:213135251
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:121267914
Failed to save title 0 to file D:/Rips/MakeMKV/title00.mkv
0 titles saved, 1 failed
