Escape Plan (2013)
Chipwager
Escape Plan (2013)
Post by Chipwager »
Does anyone know which .mpls to rip? There are so many to choose from. Thanks in advance.
PMJohnson9
Re: Escape Plan (2013)
Post by PMJohnson9 »
I am going to go with 496. Using the latest version 1.8.8 it lists this as the PRIMARY TITLE. I guess this is a new feature in 1.8.8 to get past just this situation. Maybe Mike can elaborate on this. For now I will rip this title and report back when I have a chance to watch the film..
Chipwager
Post by Chipwager »
I didn't even realize there was an update to the program. Thanks for the info and for your help! :mrgreen:
christen
Post by christen »
I have another question regarding this this movie. I tried to rip the movie, but I am getting the following errors. It also failed to play in WinDVD Pro 2011, which no other bluray has had issues before.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0826CD1B66EC2AE6F83AED4022BF92BF6FC to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..042AC842CE7EACF02F7669CA3BC620C110E to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C347A8A8D27AB248A10D79E6B3C1FE6F47 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E86F4FB182046BB12171D0E04C2638FDC1 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BD1AAA0C6FFCC636F42BB2E7F4F64006EF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0162229874385CE81DA9C8958C55D76FFA4 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04C3F66CA329978BA6DEE40A5611CB4C194 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FFC92F820ACA49A068BAD096D78ADFFCCB to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B58B67E9463587F82FFB104970082164C9 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F7F57C6C512359466D540813D5EAB22F08 to device 'SPTI:\Device\CdRom0'
Highest AACS version is v44 , MKB saved as C:\Users\Christen/.MakeMKV/MKB_v44_ESCAPE_PLAN.tgz
0X7B2
Post by 0X7B2 »
I just watched 496. Seemed in order except just before 42 minutes it "replays" the last 30 seconds or so. Is anyone else seeing this?
christen
Post by christen »
Never mind. Seems that a bluray player software I had installed on the pc was causing the problem. It's solved. Now just figuring out the correct file.
PMJohnson9
0X7B2 wrote:I just watched 496. Seemed in order except just before 42 minutes it "replays" the last 30 seconds or so. Is anyone else seeing this?
Yeah I got a repeat as well. Didn't notice the time but it was the scene where the warden questions Arnold about the location of his former boss...
Guess we need to keep looking. I'm currently trying to find the exact run time online since I don't have an actual player to throw this disc in.. hence the need for MakeMKV in the first place! lol
Chipwager
Post by Chipwager »
I experienced the same skip. Good enough imo, lol. :o Would be nice to have the correct one though.
unab0mb
Post by unab0mb »
Should be 00578.mpls . I'm ripping now to confirm. If anyone else watches it before I do, please post.
christen
Post by christen »
My Sony bluray player reports 1:55:35 as the runtime.
repstein
Post by repstein »
00578.mpls and 00679.mpls are the only run times that match (1:55:35).
unab0mb
Post by unab0mb »
Confirmed. 00578.mpls is the winner.
PMJohnson9
unab0mb wrote:Confirmed. 00578.mpls is the winner.
Just finished watching through it myself - I concur with 578..
Post by mike admin »
PMJohnson9 wrote:I am going to go with 496. Using the latest version 1.8.8 it lists this as the PRIMARY TITLE. I guess this is a new feature in 1.8.8 to get past just this situation. Maybe Mike can elaborate on this. For now I will rip this title and report back when I have a chance to watch the film..
Yes that is a new feature that was supposed to detect the right title. Apparently it done it wrongly.
PMJohnson9
Well thanks for the try, I am sure you will get it corrected eventually. Luckily I have not come across many discs that use this tactic. Escape Plan and Now You See Me are the only 2 in recent memory that I personally have had to play with...
