Escape Plan (2013)
Escape Plan (2013)
Does anyone know which .mpls to rip? There are so many to choose from. Thanks in advance.
Re: Escape Plan (2013)
I am going to go with 496. Using the latest version 1.8.8 it lists this as the PRIMARY TITLE. I guess this is a new feature in 1.8.8 to get past just this situation. Maybe Mike can elaborate on this. For now I will rip this title and report back when I have a chance to watch the film..
I didn't even realize there was an update to the program. Thanks for the info and for your help!
I have another question regarding this this movie. I tried to rip the movie, but I am getting the following errors. It also failed to play in WinDVD Pro 2011, which no other bluray has had issues before.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0826CD1B66EC2AE6F83AED4022BF92BF6FC to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..042AC842CE7EACF02F7669CA3BC620C110E to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C347A8A8D27AB248A10D79E6B3C1FE6F47 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E86F4FB182046BB12171D0E04C2638FDC1 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BD1AAA0C6FFCC636F42BB2E7F4F64006EF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0162229874385CE81DA9C8958C55D76FFA4 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04C3F66CA329978BA6DEE40A5611CB4C194 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FFC92F820ACA49A068BAD096D78ADFFCCB to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B58B67E9463587F82FFB104970082164C9 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0F7F57C6C512359466D540813D5EAB22F08 to device 'SPTI:\Device\CdRom0'
Highest AACS version is v44 , MKB saved as C:\Users\Christen/.MakeMKV/MKB_v44_ESCAPE_PLAN.tgz
I just watched 496. Seemed in order except just before 42 minutes it "replays" the last 30 seconds or so. Is anyone else seeing this?
Never mind. Seems that a bluray player software I had installed on the pc was causing the problem. It's solved. Now just figuring out the correct file.
Yeah I got a repeat as well. Didn't notice the time but it was the scene where the warden questions Arnold about the location of his former boss...0X7B2 wrote:I just watched 496. Seemed in order except just before 42 minutes it "replays" the last 30 seconds or so. Is anyone else seeing this?
Guess we need to keep looking. I'm currently trying to find the exact run time online since I don't have an actual player to throw this disc in.. hence the need for MakeMKV in the first place! lol
I experienced the same skip. Good enough imo, lol.PMJohnson9 wrote:Yeah I got a repeat as well. Didn't notice the time but it was the scene where the warden questions Arnold about the location of his former boss...0X7B2 wrote:I just watched 496. Seemed in order except just before 42 minutes it "replays" the last 30 seconds or so. Is anyone else seeing this?
Should be 00578.mpls . I'm ripping now to confirm. If anyone else watches it before I do, please post.
My Sony bluray player reports 1:55:35 as the runtime.
00578.mpls and 00679.mpls are the only run times that match (1:55:35).
Confirmed. 00578.mpls is the winner.
Just finished watching through it myself - I concur with 578..unab0mb wrote:Confirmed. 00578.mpls is the winner.
- Contact:
Yes that is a new feature that was supposed to detect the right title. Apparently it done it wrongly.PMJohnson9 wrote:I am going to go with 496. Using the latest version 1.8.8 it lists this as the PRIMARY TITLE. I guess this is a new feature in 1.8.8 to get past just this situation. Maybe Mike can elaborate on this. For now I will rip this title and report back when I have a chance to watch the film..
Well thanks for the try, I am sure you will get it corrected eventually. Luckily I have not come across many discs that use this tactic. Escape Plan and Now You See Me are the only 2 in recent memory that I personally have had to play with...mike admin wrote:Yes that is a new feature that was supposed to detect the right title. Apparently it done it wrongly.PMJohnson9 wrote:I am going to go with 496. Using the latest version 1.8.8 it lists this as the PRIMARY TITLE. I guess this is a new feature in 1.8.8 to get past just this situation. Maybe Mike can elaborate on this. For now I will rip this title and report back when I have a chance to watch the film..
