MPLS Bluray Order
meridius
MPLS Bluray Order
Post by meridius »
Hi there
How do you find the correct MPLS for those movies that have many titles with the same run time but have the mpls in the wrong order.
i am starting to see many movies with about 50 playlists but all have the same run time but have the mpls files in the wrong order, I can not find any tool that picks the right files is there any help on this
will makemkv be able to fix this in the future and if so how as it seems to be getting harder to rip a movie now
thanks
ndjamena
Re: MPLS Bluray Order
Post by ndjamena »
It's copy protection, even if MakeMKV could figure out how to get the correct title for current discs, the distributors could just change the way they author the discs in future to throw the prediction algorithms off. Someone posted a script recently that seems to work for now, but for the most part it's all down to trial and error.
Copy Protection = War, there's no simple way of dealing with it.
Post by mike admin »
Are you using the latest version, 1.8.8 . What is the disc that causes this with 1.8.8 ?
meridius
Post by meridius »
no have not tried the new version yet will do an will report back
