1.8.7 worked; 1.8.8 doesn't
jbbevan0444
Post by jbbevan0444 »
I have backed up a half dozen of my BDs with version 1.8.7 with no issues. I downloaded the new version 1.8.8 on Feb 2nd and nothing I have ripped since works. The rip happens alright, but the folder can no longer be seen by Handbrake in order to convert the file set to AppleTV formats. Handbrake simply reports "No files found."
At the beginning of the rip process the window shows four major errors before proceeding to rip the entire file set. I went back to 1.8.7 and the process worked well, again. There seems to be some sort of glitch in 1.8.8. :(
taseldor
Re: 1.8.7 worked; 1.8.8 doesn't
Post by taseldor »
Agreed, except on this end the rip doesn't even succeed. I have tried to back up a couple of my Criterion BDs with 1.8.8 and the program didn't even make it through "Analyzing Seamless Segments" before failing. I have never had this problem with a previous release.
I'm running OSX 10.8.5 in case that makes any difference.
Post by mike admin »
Please enable debug log in preferences (/faq/item/8/catid/6) and post here the log file. Thank you.
taseldor
Post by taseldor »
It says the board attachment quota has been reached, but here's the pertinent part. It seems to be a problem with BDs with LPCM audio:
005014:0000 Saving 1 titles into directory /Volumes/Movies
001003:0020 DEBUG: Code 402766720 at E`7<gT{9|;*q!";?k)4<:213137160
001003:0020 DEBUG: Code 0 at E`7<gT{9|;*q!";?k)4<:121268972
001003:0020 DEBUG: Code 0 at {\"enh{o9tu$^a,:121263429
001003:0020 DEBUG: Code 1 at {weTEN\zOLR`4?ik:(:213131272
001003:0020 DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:121263084
001002:0020 LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
001003:0020 DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:213132560
001003:0020 DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:29397794
001003:0020 DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:213135251
001003:0020 DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:121267914
005003:0000 Failed to save title 0 to file /Volumes/Movies/redacted.mkv
Speedviktm
Post by Speedviktm »
Same here, started a different thread since I was only getting that error on a "homemade" disc I got while on vacation, thought it might have been an issue with discs created with Vegas Pro. Re-installed v1.8.7 and it seems to be working fine.
MakeMKV v1.8.8 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Doug/MakeMKV_log.txt
AACS directory not present, assuming unencrypted disc
File 00001.mpls was added as title #0
Title #00000.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Rips/MakeMKV
DEBUG: Code 402832256 at X\<GHV9%hv#|>M9`j%w":213137160
DEBUG: Code 0 at X\<GHV9%hv#|>M9`j%w":121268972
DEBUG: Code 0 at 30JU:?DhC`<]%,<:121263429
DEBUG: Code 1 at T\]8`),IY9.8H2il'F:213131272
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:121263084
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:213132560
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:29397794
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:213135251
DEBUG: Code 0 at T\]8`),IY9.8H2il'F:121267914
Failed to save title 0 to file D:/Rips/MakeMKV/title00.mkv
0 titles saved, 1 failed
