1.8.8 > Enter registration key > Can not paste key
onthebeach
#1 Post by onthebeach » Sun Feb 02, 2014 10:33 pm
Hi Mods,
I have 1.8.8 installed and am trying to "paste" the new key into the "Enter registration key" form.
Paste is not available as an option.
Are you able to advise a workaround?
Thanks. :D
onthebeach
Re: 1.8.8 > Enter registration key > Can not paste key
#2 Post by onthebeach » Sun Feb 02, 2014 11:18 pm
Debug Log:
Debug log started at Sun Feb 02 23:14:18 2014 , written by MakeMKV v1.8.8 win(x64-release)
001005:0000 MakeMKV v1.8.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\xxx/MakeMKV_log.txt
005055:0000 Evaluation period has expired, shareware functionality unavailable.
005052:0204 Evaluation period has expired. Please purchase an activation key if you've found this application useful. You may still use all free functionality without any restrictions.
001003:0020 DEBUG: Code 0 at vO*SQ4OIu;S!*oA{:29395402
001003:0020 DEBUG: Code 0 at vO*SQ4OIu;S!*oA{:29396943
001003:0020 DEBUG: Code 233 at fNomhHttdmDhbbEKZsxctAe3:0
001003:0020 DEBUG: Code 233 at yCmFVksGAbE76Rq0FuzAKYMv:0
Application exited at Sun Feb 02 23:15:41 2014
onthebeach
#3 Post by onthebeach » Sun Feb 02, 2014 11:38 pm
I've since rolled back to 1.8.7. Updated the key successfully. I'll continue using this version for the time being.
#4 Post by mike admin » Tue Feb 04, 2014 8:40 am
Please try installing 1.8.8 now - the key should still be valid.
What do you mean by "paste is not available", is it grayed in menu? What happens if you press Ctrl+V ?
onthebeach
#5 Post by onthebeach » Tue Feb 04, 2014 11:09 pm
Yes, have since reinstalled 1.8.8.
Problem, I believe, was: the prev key had run out on 1.8.7. I then upgraded to 1.8.8 without updating the key.
When I started 1.8.8 - I received the "evaluation key is out of date" message. When I went to paste the new key in - the form was greyed out and Ctl+V didn't work either.
As per my earlier messages - I rolled back to 1.8.7, updated the key and then did the install of 1.8.8.
All working now. Thanks for the follow up.
