Is there a way to open a backup created by MakeMKV?
It seems there should be:
but the Open Files menu option only allows you to pick a file, not a folder
and the Open Disk menu option only allows you to select a device.
Thanks.
Opening a Backup
- Contact:
Re: Opening a Backup
Yes, any file available for selection inside BDMV folder.
Yes! That worked perfectly.
Thank you very much.
