problem with HD-DVDs
jurld
Post by jurld »
I've got a lot of unencrypted ISOs on a network drive that I mount with Virtual Clone Drive. I've been converting them so I can watch with VLC. I can convert Blu-Rays from there without trouble. But the several HD-DVDs I've tried all fail within approximately 30 seconds of clicking Make MKV button with:
MakeMKV v1.8.7 win(x64-release) started
AACS directory not present, assuming unencrypted disc
Saving 1 titles into directory E:/MadeMKVs
Failed to save title 0 to file E:/MadeMKVs/_t00.mkv
0 titles saved, 1 failed
Smithcraft
Re: problem with HD-DVDs
Post by Smithcraft »
Please consider turning on the debugging messages in the preferences, and try to scan again, and post that log.
SC
jurld
Post by jurld »
Here you go:
Debug logging enabled, log will be saved as C:\Users\Turgon/MakeMKV_log.txt
DEBUG: Code 0 at |v8pAS,=n~vb~)-O;:121262164
DEBUG: Code 0 at N(!LLW.xM"Hl!e)}P$\:29396299
Saving 1 titles into directory E:/MadeMKVs <--- sits here for about 40 seconds then fails
DEBUG: Code 0 at ^k(h-AvkRp`%^bzDr4_:121263820
DEBUG: Code 0 at AsEg3|1vZX"LU'8]?q}N:121262739
DEBUG: Code 0 at l1;{3&6hr=C{IiB}Air:121261681
DEBUG: Code 0 at AsEg3|1vZX"LU'8]?q}N:213130743
DEBUG: Code 62153 at AsEg3|1vZX"LU'8]?q}N:29393332
DEBUG: Code 0 at IY2v.p;V.7|,gSWb@a:nd:29398622
Failed to save title 0 to file E:/MadeMKVs/Feature_Presentation_t00.mkv
The mounted ISO does play in an ancient version of PowerDVD.
Post by mike admin »
looks like a very broken ISO. Please try:
1 - opening the ISO file itself instead of mounted image from MakeMKV (file->Open)
2 - if (1) fails, try extracting all files from ISO to a folder and open the files with MakeMKV.
jurld
Post by jurld »
I'll give it a shot.
This happens with all HD-DVDs backups I've tried so far, so perhaps something hosed about the way they were created. Though, they do play fine in old version of Power-DVD.
jurld
Post by jurld »
#1 fails with same error. Will try #2 now.
jurld
Post by jurld »
Extracting the files to a folder and attempting to open them (either HVA00001.VTI or DISCID.DAT) with MakeMKV resulted in a sub-set of the same errors:
DEBUG: Code 0 at AsEg3|1vZX"LU'8]?q}N:121262762
DEBUG: Code 57290 at AsEg3|1vZX"LU'8]?q}N:29393332
jurld
Post by jurld »
Why would this play in Power DVD and not convert with MKV?
Are there alternatives?
The EVO files are encrypted but AACS directory not present, plus few MAP files are missing. This is a very damaged rip - you'll have to use the original disc.
jurld
Post by jurld »
Well, the files are NOT encrypted. They play fine in Power DVD 7.
jurld wrote:Well, the files are NOT encrypted. They play fine in Power DVD 7.
Maybe they are not, but they surely are marked as encrypted.
jurld
Post by jurld »
Is this set in a header somewhere? Might I be able to hex-edit the ISO to clear that tag?
