Hi there.. Thank you for your excellent product.
On a new OS build, I'm using autorip.exe and calling MakeMKV. I note that after a reboot, autorip reports "Oops! This script needs MakeMKV installed.." MakeMKV *is* installed, of course. If I re-apply the beta key, everything goes back to working for the rest of the session, but then on reboot, it re-occurs. I'd thought it was a problem with the beta key, so today I just went ahead and purchased the software and registered it with the paid-for key. Nope, same problem on reboot.
Please advise.
Thank you!
Erroneous "Oops! This script needs MakeMKV installed.." msg
Re: Erroneous "Oops! This script needs MakeMKV installed.."
I tried to have makemkv running before autorip tries to pass any jobs to it, but it still didn't work. But once I hit help/register/ok (my paid key is saved), it works fine.
