Opening a Backup
bitbug
Opening a Backup
#1 Post by bitbug » Thu Jan 30, 2014 8:51 pm
Is there a way to open a backup created by MakeMKV?
It seems there should be:
but the Open Files menu option only allows you to pick a file, not a folder
and the Open Disk menu option only allows you to select a device.
Thanks.
Re: Opening a Backup
#2 Post by mike admin » Sun Feb 02, 2014 9:32 am
Yes, any file available for selection inside BDMV folder.
bitbug
#3 Post by bitbug » Mon Feb 03, 2014 3:29 am
Yes! That worked perfectly.
Thank you very much.
