Copying blu ray with subtitles
TempGuy1
Post by TempGuy1 » Tue Jan 28, 2014 4:25 am
Forgive me if this is a newb question but I've searched the forums high and low and can't find an answer to my question.
How do you make a copy of a blu ray with subtitles? For example, "The Wolverine" has some scenes in Japanese where English subtitles should appear.
After I rip the MKV with MakeMKV (leaving the subtitles checked) how do I mux it and include the subtitles so they appear in playback? TSMuxer doesn't recognize the subtitles and won't add them. Is there a simple way or do you have to somehow extract the subtitles and use another program to add them back after it's muxed? Please help...I've turned a few disks into coasters attempting this.
To clarify, I'm making the disk Blu Ray compatible so it plays in standalone Blu Ray players.
Chetwood
Re: Copying blu ray with subtitles
Post by Chetwood » Tue Jan 28, 2014 5:52 am
If you really want a Bluray as output format, why use MakeMKV? And TSMuxer DOES recognize subs.
ndjamena
Post by ndjamena » Tue Jan 28, 2014 12:36 pm
Extract the subtitles into .sup files first, then add the .sup files into TSMuxer along with the MKV.
As far as I can tell, TSMuxerGUI doesn't recognise PGS subtitles in Matroska Files.
TempGuy1
Post by TempGuy1 » Wed Jan 29, 2014 3:15 am
Chetwood wrote:If you really want a Bluray as output format, why use MakeMKV? And TSMuxer DOES recognize subs.
I extract the MKV, then if it's too big, handbrake it until it fits on a BD25 disk. When I throw the MKV into TSMuxer, it says "track not recognized" and subtitles don't output. Even if I throw an MKV that hasn't been encoded in handbrake, TSmuxer still doesn't recognize the subtitle track.
TempGuy1
Post by TempGuy1 » Wed Jan 29, 2014 3:16 am
ndjamena wrote:Extract the subtitles into .sup files first, then add the .sup files into TSMuxer along with the MKV.
How do I extract the subtitles?
ndjamena
Post by ndjamena » Wed Jan 29, 2014 3:24 am
MKVCleaver if you need a GUI or you could use MKVExtract directly, I have a batch that will do it automatically, but I've written a MediaInfo to Batch program using c++ that you'd need as well.
ndjamena
Post by ndjamena » Wed Jan 29, 2014 3:50 am
http://www.mediafire.com/download/54qxd ... aBatch.zip
I haven't had time to perfect it yet and you'll need the 32 bit MediaInfo.dll installed as well.
Extract - Subtitles.bat:
@CALL Extract.bat "--folder" "D:\Videos2" "--subtitles" "ONLY" %*
Extract.bat:
@if "%EMode%"=="" Set EMode=OFF
@ECHO %EMode%
SetLocal DisableDelayedExpansion
Set "Dest=D:\Ins2\"
Set "EXTLIST=*.mkv"
Set "Extract_Mode=folder"
Set "Extract_Folder=%Dest%"
Set "Add_File_Name=0"
Set "Add_Type_Enum=1"
Set "Sub_Folder="
Set "Video_Tog=1"
Set "Audio_Tog=1"
Set "Subtitles_Tog=1"
Set "D2V=0"
Set "DoPop="
if [%1]==[] (
	Set "Pattern=%EXTLIST%"
	CALL :START %1
:ARGS
	if [%1]==[] (
		EndLocal
		pause
		goto :eof
	if /I "%~1"=="--addfilename" (
		if NOT [%2]==[] (
			if /I "%~2"=="OFF" (
				SHIFT
			) else (
				if /I "%~2"=="ON" (
					Set "Add_File_Name=1"
					SHIFT
				) else (
					if "%Add_File_Name%"=="1" (
					) else (
		SHIFT
		goto :ARGS
	if /I "%~1"=="--noenum" (
		Set "Add_Type_Enum=0"
		SHIFT
		goto :ARGS
	if /I "%~1"=="--typeenumex" (
		SHIFT
		goto :ARGS
	if /I "%~1"=="--typeenum" (
		Set "Add_Type_Enum=2"
		SHIFT
		goto :ARGS
	if /I "%~1"=="--ID" (
		Set "Add_Type_Enum=3"
		SHIFT
		goto :ARGS
	if /I "%~1"=="--tracknum" (
		Set "Add_Type_Enum=4"
		SHIFT
		goto :ARGS
	if /I "%~1"=="--UID" (
		Set "Add_Type_Enum=5"
		SHIFT
		goto :ARGS
	if /I "%~1"=="--enum" (
		Set "Add_Type_Enum=6"
		SHIFT
		goto :ARGS
	if /I "%~1"=="--dump" (
		Set "Extract_Mode=dump"
		Set "Extract_Folder="
		SHIFT
		goto :ARGS
	if /I "%~1"=="--dumpasfolder" (
		SHIFT
		goto :ARGS
	if /I "%~1"=="--dumpinfolder" (
		if NOT [%2]==[] (
			Set "Extract_Folder=%~2"
			if NOT EXIST "%~2" mkdir "%~2"
			SHIFT
		SHIFT
		goto :ARGS
	if /I "%~1"=="--folder" (
		if NOT [%2]==[] (
			SHIFT
		SHIFT
		goto :ARGS
	if /I "%~1"=="--subfolder" (
		if NOT [%2]==[] (
			Set "Extract_Sub=%~2"
			if /I "%~2"=="None" Set "Extract_Sub="
			SHIFT
		) else (
			Set "Extract_Sub="
		SHIFT
		goto :ARGS
	if /I "%~1"=="--video" (
		if NOT [%2]==[] (
				Set "Video_Tog=0"
				SHIFT
			) else (
				if /I "%~2"=="ON" (
					Set "Video_Tog=1"
					SHIFT
				) else (
					if /I "%~2"=="ONLY" (
						Set "Video_Tog=1"
						Set "Audio_Tog=0"
						Set "Subtitle_Tog=0"
						SHIFT
					) else (
						if /I "%~2"=="EXCEPT" (
							Set "Video_Tog=0"
							Set "Audio_Tog=1"
							Set "Subtitle_Tog=1"
							SHIFT
						) else (
							if "%Video_Tog%"=="1" (
								Set "Video_Tog=0"
							) else (
								Set "Video_Tog=1"
		SHIFT
		goto :ARGS
	if /I "%~1"=="--audio" (
		if NOT [%2]==[] (
				Set "Audio_Tog=0"
				SHIFT
			) else (
				if /I "%~2"=="ON" (
					Set "Audio_Tog=1"
					SHIFT
				) else (
						Set "Video_Tog=0"
						Set "Audio_Tog=1"
						SHIFT
					) else (
							Set "Video_Tog=1"
							Set "Audio_Tog=0"
							SHIFT
						) else (
							if "%Audio_Tog%"=="1" (
								Set "Audio_Tog=0"
							) else (
								Set "Audio_Tog=1"
		SHIFT
		goto :ARGS
	if /I "%~1"=="--subtitles" (
		if NOT [%2]==[] (
				Set "Subtitles_Tog=0"
				SHIFT
			) else (
				if /I "%~2"=="ON" (
					SHIFT
				) else (
						Set "Video_Tog=0"
						Set "Audio_Tog=0"
						SHIFT
					) else (
							Set "Video_Tog=1"
							Set "Audio_Tog=1"
							SHIFT
						) else (
							if "%Subtitles_Tog%"=="1" (
							) else (
		SHIFT
		goto :ARGS
	if /I "%~1"=="--d2v" (
		if NOT [%2]==[] (
				Set "D2V=0"
				SHIFT
			) else (
				if /I "%~2"=="ON" (
					Set "D2V=1"
					SHIFT
				) else (
					if "%D2V%"=="1" (
						Set "D2V=0"
					) else (
						Set "D2V=1"
		SHIFT
		goto :ARGS
	if /I "%~1"=="--reset" (
		Set "Sub_Folder="
		Set "Video_Tog=1"
		Set "Audio_Tog=1"
		Set "D2V=1"
		if NOT EXIST "%Dest%" mkdir "%Dest%"
		SHIFT
		goto :ARGS
	if NOT EXIST %1 (
		SHIFT
		goto :ARGS
	if "%~f1"=="%CD%" (
		CALL :START %1
		SHIFT
		goto :ARGS
	Type NUL
	pushd "%~f1" 2> nul
	if NOT "%errorlevel%"=="0" (
		if NOT "%CD%\"=="%~dp1" (
			pushd "%~dp1"
			Set "DoPop=1"
		Set Pattern="%~nx1"
	) else (
		Set "DoPop=1"
	CALL :START %1
	if "%DoPop%"=="1" (
		popd
		Set "DoPop="
	SHIFT
goto :ARGS
:START
	if "%Extract_Folder%"=="" Set "Extract_Folder=\"
	if NOT "%Extract_Folder:~-1,1%"=="\" Set "Extract_Folder=%Extract_Folder%\"
	if "%Extract_Folder%"=="\" Set "Extract_Folder="
	if "%Extract_Sub%"=="" Set "Extract_Sub=\"
	if NOT "%Extract_Sub:~-1,1%"=="\" Set "Extract_Sub=%Extract_Sub%\"
	if "%Extract_Sub%"=="\" Set "Extract_Sub="
	for %%y in (%Pattern%) do (
		CALL :Process_File "%%~fy"
		EndLocal
goto :eof
:Process_File
	cls
	Set "Source_Name=%~n1"
	Set "FolderName=%~n1"
	Set "ExtractList="
	Set "IndexCOM="
	Set "DoIndex="
	if NOT "%DEL_LIST%"=="" CALL :DEL_VARS
	if "%FolderName:~-1%"=="." (
		Set "FolderName=%FolderName%.dot"
	) else (
		if "%FolderName:~-4%"==".dot" (
	if "%Extract_Mode%"=="dump" (
		if "%Extract_Folder%"=="" (
			Set "FolderName=%~dp1"
		) else (
			Set "FolderName=%Extract_Folder%"
	if "%Extract_Mode%"=="folder" (
			Set "FolderName=%~dp1%FolderName%\"
			if NOT Exist "%~dp1%FolderName%\" mkdir "%~dp1%FolderName%\"
		) else (
			Set "FolderName=%Extract_Folder%%FolderName%\"
			if NOT Exist "%Extract_Folder%%FolderName%\" mkdir "%Extract_Folder%%FolderName%\"
	if NOT "%Extract_Sub%"=="" (
		Set "FolderName=%FolderName%%Extract_Sub%"
		if NOT Exist "%FolderName%%Extract_Sub%" mkdir "%FolderName%%Extract_Sub%"
	Set AU=0
	Set ST=0
	Set VD=0
	echo Processing; "%~n1"
	for /f "tokens=1,2,*" %%g in ('MyMediaBatch.exe %1') do (
		CALL :Process_item %%g %%h "%%i" %1
	Set /a Check=VD+AU+ST
	rem Set IndexCOM=
	echo.
	if "%Check%"=="0" (
		echo Nothing to do!
		timeout 3
	) else (
		echo Extracting Tracks;
		echo 0^|----^|10^|----^|20^|----^|30^|----^|40^|----^|50^|----^|60^|----^|70^|----^|80^|----^|90^|----^|
		Set "Progress_Var=0"
		for /f "tokens=1,*" %%j in ('MKVEXTRACT tracks %1%ExtractList%') do (
			echo %%j %%k>>"Z:\Work\Extract.log"
			if "%%j"=="Progress:" CALL :Progress_Bar "%%k"
		CALL :Progress_Bar "100"
		echo.
		if NOT "%DoIndex%"=="" (
			echo.
			echo Creating Index File;
			for /f "tokens=1,*" %%j in ('DGIndex.exe %IndexCOM%') do (
				CALL :Progress_Bar "%%j"
			echo.
goto :eof
:Process_item
	if "%~1"=="Prg" (
		if "%~2"=="Err" (
			CALL ERROR: "%~f3"
			pause
		goto :eof
	if "%~1"=="File" goto :eof
	if "%~2"=="Start" (
		Set "Codec=None"
		goto :eof
	if "%~2"=="End" (
		if "%Codec%"=="V_MPEG2" CALL :EXTRACT_TRACK_VD m2v "%~f4"
		if "%CodecStructure%"=="V_MS/VFW/FOURCC" CALL :EXTRACT_TRACK_VD avi "%~f4"
		rem if "%Codec%"=="WVC1" CALL :EXTRACT_TRACK_VD avi "%~f4"
		if "%Codec%"=="V_MPEG4/ISO/AVC" CALL :EXTRACT_TRACK_VD h264 "%~f4"
		if "%Codec:~0,7%"=="V_REAL/" CALL :EXTRACT_TRACK_VD real "%~f4"
		if "%Codec%"=="V_THEORA" CALL :EXTRACT_TRACK_VD ogg "%~f4"
		if "%Codec%"=="V_VP8" CALL :EXTRACT_TRACK_VD ivf "%~f4"
		if "%Codec%"=="V_VP9" CALL :EXTRACT_TRACK_VD ivf "%~f4"
		if "%Codec%"=="A_DTS" (
			if "%CodecEx%"=="MA" CALL :EXTRACT_TRACK_AU dts-ma "%~f4"
			if "%CodecEx%"=="HRA" CALL :EXTRACT_TRACK_AU dts-hra "%~f4"
			if "%CodecEx%"=="ES" CALL :EXTRACT_TRACK_AU dts-es "%~f4"
			if "%CodecEx%"=="" CALL :EXTRACT_TRACK_AU dts "%~f4"
		if "%Codec%"=="A_TRUEHD" CALL :EXTRACT_TRACK_AU thd "%~f4"
		if "%Codec%"=="A_AC3" CALL :EXTRACT_TRACK_AU ac3 "%~f4"
		if "%Codec%"=="A_AAC" CALL :EXTRACT_TRACK_AU aac "%~f4"
		if "%Codec:~0,12%"=="A_AAC/MPEG2/" CALL :EXTRACT_TRACK_AU aac "%~f4"
		if "%Codec%"=="A_PCM/INT/LIT" CALL :EXTRACT_TRACK_AU wav "%~f4"
		if "%Codec%"=="A_MPEG/L2" CALL :EXTRACT_TRACK_AU m2p "%~f4"
		if "%Codec%"=="A_MPEG/L3" CALL :EXTRACT_TRACK_AU mp3 "%~f4"
		if "%Codec%"=="A_VORBIS" CALL :EXTRACT_TRACK_AU ogg "%~f4"
		if "%Codec:~0,7%"=="A_REAL/" CALL :EXTRACT_TRACK_AU real "%~f4"
		if "%Codec%"=="A_TTA1" CALL :EXTRACT_TRACK_AU tta "%~f4"
		if "%Codec%"=="A_ALAC" CALL :EXTRACT_TRACK_AU caf "%~f4"
		if "%Codec%"=="A_WAVPACK4" CALL :EXTRACT_TRACK_AU wv "%~f4"
		if "%Codec%"=="A_OPUS" CALL :EXTRACT_TRACK_AU ogg "%~f4"
		if "%Codec%"=="S_HDMV/PGS" CALL :EXTRACT_TRACK_ST sup "%~f4"
		if "%Codec%"=="S_VOBSUB" CALL :EXTRACT_TRACK_ST idx "%~f4"
		if "%Codec%"=="S_TEXT/UTF8" CALL :EXTRACT_TRACK_ST srt "%~f4"
		if "%Codec%"=="S_TEXT/SSA" CALL :EXTRACT_TRACK_ST ssa "%~f4"
		if "%Codec%"=="S_TEXT/ASS" CALL :EXTRACT_TRACK_ST ass "%~f4"
		if "%Codec%"=="S_KATE" CALL :EXTRACT_TRACK_ST ogg "%~f4"
		if "%Codec%"=="S_TEXT/USF" CALL :EXTRACT_TRACK_ST usf "%~f4"
		if "%Codec%"=="None" Set "Codec="
		CALL :DEL_VARS
		goto :eof
	Set "%~2=%~3"
	Set "DEL_LIST=%DEL_LIST%%~2 "
goto :eof
:DEL_VARS
	for %%y in (%DEL_LIST%) do (
		set "%%y="
	set "DEL_LIST="
goto :eof
:EXTRACT_TRACK_AU
	if "%Audio_Tog%"=="0" goto :eof
	Set /a AU=AU+1
	Set "File_Name="
	if "%Add_File_Name%"=="1" Set "File_Name=%Source_Name%"
	if "%Add_File_Name%"=="1" if NOT "%Add_Type_Enum%"=="0" Set "File_Name=%File_Name% ("
	if "%Add_Type_Enum%"=="1" Set "File_Name=%File_Name%%TypeEnumEx%"
	if "%Add_Type_Enum%"=="2" Set "File_Name=%File_Name%%TypeEnum%"
	if "%Add_Type_Enum%"=="3" Set "File_Name=%File_Name%ID_%TrackID%"
	if "%Add_Type_Enum%"=="4" Set "File_Name=%File_Name%Track_#%ID%"
	if "%Add_Type_Enum%"=="5" Set "File_Name=%File_Name%UID_%UID%"
	if "%Add_Type_Enum%"=="6" Set "File_Name=%File_Name%Track_%TrackOrder%"
	if "%Add_File_Name%"=="1" if NOT "%Add_Type_Enum%"=="0" Set "File_Name=%File_Name%)"
	Set ExtractList=%ExtractList% %TrackID%:"%FolderName%%File_Name%.%1"
	echo Track %TrackID%:"%FolderName%%File_Name%.%1"
goto :eof
:EXTRACT_TRACK_ST
	if "%Subtitle_Tog%"=="0" goto :eof
	Set /a ST=ST+1
	Set "File_Name="
goto :eof
:EXTRACT_TRACK_VD
	if "%Video_Tog%"=="0" goto :eof
	Set /a VD=VD+1
	Set "File_Name="
	if "%D2V%"=="1" if "%1"=="m2v" (
		Set IndexCOM=-ia 3 -i "%FolderName%%File_Name%.%1" -o "%FolderName%%File_Name%" -hide -exit
		Set DoIndex=1
goto :eof
:OUT_ERROR
	echo ERROR: %~1
goto :eof
:Progress_Bar
	if %~1 GTR %Progress_Var% (
		echo ?? | set /p Dummy=??
		Set /a Progress_Var+=5
	if %~1 GTR %Progress_Var% goto :Progress_Bar
	TITLE Progress: %~1
goto :eof
Even easier than MKVCleaver...
Chetwood
Post by Chetwood » Wed Jan 29, 2014 6:25 am
TempGuy1 wrote:I extract the MKV, then if it's too big, handbrake it until it fits on a BD25 disk.
Again: why use MakeMKV when it does not compress? To resize BD structures you'd usually use DVDFab or something.
ndjamena
Post by ndjamena » Wed Jan 29, 2014 8:20 am
MakeMKV is free while in Beta. Handbrake and TSMuxer are free, period.
My trial of DVDFab has expired, so I can't test to see if it's any better.
Chetwood
Post by Chetwood » Wed Jan 29, 2014 12:00 pm
The rip function of DVDfab stays free. Period.
And you too fail to explain why he would need MakeMKV to get from m2ts to m2ts.
ndjamena
Post by ndjamena » Wed Jan 29, 2014 12:55 pm
Agreed, DVDFab is an option.
Handbrake should be able to read the DVDFab Blu Ray structure to get at the chapters and encode the Video. Then you add the Handbrake encode and the M2TS file to TSMuxer to create a Blu Ray.
Or, rip with MakeMKV, re-encode the file, extract the subtitles and add the Handbrake encode and the subtitles to TSMuxer to create a Blu Ray.
I guess it's a matter of personal preference.
ndjamena
Post by ndjamena » Sat Feb 01, 2014 9:48 pm
MakeMKV Back-up + BD Rebuilder looks promising, you even get to keep the menus.
http://www.videohelp.com/tools/BD-Rebuilder
TempGuy1
Post by TempGuy1 » Sun Feb 02, 2014 3:26 pm
I guess I don't know any other way. I thought you need to make an MKV that bundles the audio and video and keeps chapters. Are you saying to use DVDfab to decrypt all the video files then somehow put them together? What about the movies that have lots of .m2ts files in one movie?
TempGuy1
Post by TempGuy1 » Sun Feb 02, 2014 3:28 pm
BTW, I found an easier way to keep forced subtitles. You can burn them in with handbrake during the encode to compress it. Then it's just burned in and don't have to worry at all about separate subtitle tracks. It works for me at least...I'm just making it up as I go.
ndjamena
Post by ndjamena » Sun Feb 02, 2014 11:25 pm
DVDFab can make a BD25 out of a BD50 directly, but it's not part of the free HD Decrypter element of the program, so you'll only get the 30 day trial to use it. It's uses Quicksync by default on my computer, there is a software mode but I'm not sure what codec that is exactly. Other than that, it can rip the main movie to a BD structure and you can encode with handbrake or BD Rebuilder from there. I don't see how the free portions of DVDFab would make things any easier, but maybe I missed something.
Just keep doing what you're doing, at long as your happy with the outcome that's all that matters, as long as you don't make a mess of the handbrake settings it's doubtful anything can go wrong.
