Error 'OS error - The system cannot find the file specified'
Twinsborg
Post by Twinsborg »
Hi I have been using Makemkv for about 110 months and am very pleased with the product. after the last forced upgrade It does not work. I keep getting the following error... "Error 'OS error - The system cannot find the file specified' occurred while creating ....."
Whats up?
Re: Error 'OS error - The system cannot find the file specif
A debugging log that shows what is going on up to the point of the error would be helpful.
Are you running MakeMKV as an administrator? If the shortcut "lost" that attribute during the update, it would have permissions problems when trying to directly access the hardware.
