audio is only 2.0
peteyx
audio is only 2.0
#1 Post by peteyx » Wed Jan 15, 2014 12:54 am
I have well over 100 DVD files on my HTPC. All of the Blu-ray files show up in XBMC as 5.1 or 7.1 audio. Virtually all of the standard def DVD files (the majority) show up as 2.0 audio, even though I have selected 3/2.1 or whatever the best audio option may be. What am I doing wrong?
Smithcraft
Re: audio is only 2.0
#2 Post by Smithcraft » Tue Jan 21, 2014 10:29 am
How about posting a MediaInfo report from a file that you know you selected the 3/2.1 audio and only shows as 2.0.
SC
peteyx
#3 Post by peteyx » Tue Jan 21, 2014 3:22 pm
Here's one I found. I am using the latest versions of mkv and XBMC, btw.
File: /Volumes/Multimedia/Movies/Almost Famous.m4v
Format: QuickTime/MPEG-4/Motion JPEG 2000 format
Stream count: 2
Duration: 02:03:06
Bit rate: 1629 kb/s
Meta info:
creation_time: 1970-01-01 00:00:00
encoder: DigiArty AV Encoder Core
title: Almost Famous
major_brand: M4V
minor_version: 512
genre: MyDVD
compatible_brands: isomiso2
Stream 0
Type: video
Codec: mpeg4
Codec profile: Simple Scalable Profile
FourCC: mp4v
Duration: 02:03:06
Width: 640
Height: 360
Sample aspect ratio: 1:1
Display aspect ratio: 16:9
Pixel format: yuv420p
Frame rate: 23.98 fps
Bit rate: 1496 kb/s
Meta info:
handler_name: VideoHandler
language: und
Stream 1
Type: audio
Codec: aac
FourCC: mp4a
Duration: 02:03:06
Bit rate: 127 kb/s
Sample rate: 48000 Hz
Sample format: s16
Channel: 2
Meta info:
handler_name: SoundHandler
language: und
#4 Post by Woodstock » Tue Jan 21, 2014 3:30 pm
peteyx wrote:Here's one I found. I am using the latest versions of mkv and XBMC, btw.
That's not a file generated by MakeMKV - it's been processed by something to (a) compress it to a smaller size, and (b) convert it to an MP4 container.
A 2-hour MKV file, fresh from the ripping, will be 6.5 to 8 GB for a DVD, and MUCH larger for an BD.
ndjamena
#5 Post by ndjamena » Wed Jan 22, 2014 7:36 am
Um, let's see. He's using one of the WinX conversion programs and it's set it to down-convert all AC3 tracks to 2/0 AAC so he needs someone to tell him how to get it to leave it as surround sound... or something...
crowfax
#6 Post by crowfax » Wed Jan 22, 2014 5:37 pm
peteyx wrote:What am I doing wrong?
You're using WinX software and posting for help on the MakeMKV forum.
