You're Next
ArieS
You're Next
Post by ArieS »
There's a bunch of playlist.
Anyone knows which one is the correct one?
Thanks :D
DJRumpy
Re: You're Next
Post by DJRumpy »
Someone was nice enough to post a script a few weeks ago that drastically narrows this down.
It looks like good candidates are MPLS 8, 105, 496, 539, 625, and 877
Whichever of those matches the duration of the movie. I haven't checked that yet.
DJRumpy
Re: You're Next
Post by DJRumpy »
Hmm. I was able to check the duration on my disk this morning, and it's 1:34:23.
Only two MPLS's in the list match that duration.
0388.mpls
0570.mpls
UPC 3139818174
jinx100
Re: You're Next
Post by jinx100 »
Title information
Source file name: 00570.mpls
Duration: 1:34:23
Chapters count: 12
Segment count: 15
Segment map: 62,51,52,56,55,65,66,58,59,54,57,53,50,64,61
File name: You're_Next_t29.mkv
Worked for me.
ArieS
Re: You're Next
Post by ArieS »
Yes, 570 is the correct one :D
Malice
Re: You're Next
Post by Malice »
DJRumpy wrote:Someone was nice enough to post a script a few weeks ago that drastically narrows this down..
where might this script be? i have looked around but i am not quite sure what its called.
thanks
DJRumpy
Re: You're Next
Post by DJRumpy »
You can find it here: https://www.dropbox.com/s/54p8wjo6lj0j17c/FindM2TS.pl
I'll also try to attach it. (sorry, the board won't allow .pl files)
Note that I didn't write it. It just parses out the clip files to see which MPLS files they reference. You can often see quickly at a glance which tracks are promising, and which point to duplicate tracks, etc.
Just make it executable.
To execute it, just list the path tot he BD volume like so:
./FindM2TS.pl /Volumes/SomeDiskBD
Credit where credit is due. The original script came from "tappinaway". Search the forum for a RED 2 post.
Malice
Re: You're Next
Post by Malice »
DJRumpy wrote:You can find it here: https://www.dropbox.com/s/54p8wjo6lj0j17c/FindM2TS.pl
cool, thank you very much.
