Seemless Segments No Mainfilm
Martino
Post by Martino »
I ve testet Makemkv Beta and at this Time 2 of my Blurays dont work.
1. American Gangster Extended German Bluray
2. Schwerter des K?nigs - Dungeon Siege - Extended Director's Cut [3D Blu-ray] GERMAN Bluray
(Original Title : In the Name of the King: A Dungeon Siege Tale Directors Cut 3D Bluray)
The Main Films (Normal and Extended Cut?s ) are not listet in Makemkv
Only small Parts listet.
Sorry for my bad English
Re: Seemless Segments No Mainfilm
Please enable debugging and post the log generated. Instructions on how to do this are in the link in my signature.
Martino
Post by Martino »
Debug log started at Wed Jan 15 16:41:37 2014 , written by MakeMKV v1.8.7 win(x64-release)
001005:0000 MakeMKV v1.8.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Windows/MakeMKV_log.txt
003006:0000 Opening files on harddrive at F:/AMER_GANG_G51
001003:0020 DEBUG: Code 0 at 5V62d3^-*Whg>&:29393953
001003:0020 DEBUG: Code 0 at <0zZ6?EKplbrxbvX:213134239
003305:0000 AACS directory not present, assuming unencrypted disc
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 16 day(s) out of 30 remaining
001003:0020 DEBUG: Code 0 at 8RuE]nPJ( tWe06^3:121264671
001003:0020 DEBUG: Code 8 at 8RuE]nPJ( tWe06^3:213132100
001003:0020 DEBUG: Code 1 at 8RuE]nPJ( tWe06^3:213132100
003307:0000 File 00014.mpls was added as title #0
003307:0000 File 00020.mpls was added as title #1
003025:0000 Title #00037.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00040.mpls was added as title #2
003307:0000 File 00050.mpls was added as title #3
003307:0000 File 00070.mpls was added as title #4
003025:0000 Title #00121.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 0 at 8RuE]nPJ( tWe06^3:213132100
003025:0000 Title #00112.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00113.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00114.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00119.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00135.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00144.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00145.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00146.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00147.m2ts has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00148.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00149.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00150.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00151.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00152.m2ts was added as title #5
003307:0000 File 00153.m2ts was added as title #6
003307:0000 File 00154.m2ts was added as title #7
003307:0000 File 00155.m2ts was added as title #8
003307:0000 File 00156.m2ts was added as title #9
003307:0000 File 00157.m2ts was added as title #10
003307:0000 File 00158.m2ts was added as title #11
003307:0000 File 00159.m2ts was added as title #12
003307:0000 File 00160.m2ts was added as title #13
003307:0000 File 00161.m2ts was added as title #14
003307:0000 File 00162.m2ts was added as title #15
003307:0000 File 00163.m2ts was added as title #16
003307:0000 File 00164.m2ts was added as title #17
003307:0000 File 00165.m2ts was added as title #18
003025:0000 Title #00174.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00175.m2ts was added as title #19
003307:0000 File 00176.m2ts was added as title #20
003025:0000 Title #00222.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00223.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00224.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00225.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00226.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00227.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00228.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00229.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00230.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00231.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00232.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00233.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00234.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00235.m2ts was added as title #21
003307:0000 File 00236.m2ts was added as title #22
003307:0000 File 00237.m2ts was added as title #23
003307:0000 File 00238.m2ts was added as title #24
001003:0020 DEBUG: Code 233 at NnNwc+WAqWhSziU2435GX9Pz:0
Application exited at Wed Jan 15 16:43:00 2014
Martino
Post by Martino »
Debug log started at Wed Jan 15 16:45:07 2014 , written by MakeMKV v1.8.7 win(x64-release)
003335:0508 It appears that you have AnyDVD enabled. MakeMKV should process discs with most sophisticated protections without help of any 3rd party decryption software. In addition MakeMKV works faster and more reliably when it decrypts data by itself. It is highly recommended to disable AnyDVD and restart the application.
Do you want to continue anyway (errors may follow) ?
DISCID=97978E37BC7D3C67DDD1120650F26D6581FF23E5F12F45F45
:0000 Title #00003.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00117.mpls was added as title #0
003307:0000 File 00116.mpls was added as title #1
003307:0000 File 00115.mpls was added as title #2
003025:0000 Title #00114.mpls has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00113.mpls was added as title #3
003307:0000 File 00102.mpls was added as title #4
003307:0000 File 00101.mpls was added as title #5
003307:0000 File 00104.mpls was added as title #6
003307:0000 File 00103.mpls was added as title #7
003307:0000 File 00400.mpls was added as title #8
003025:0000 Title #00111.mpls has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00110.mpls was added as title #9
003025:0000 Title #00109.mpls has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00108.mpls has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00107.mpls has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00106.mpls was added as title #10
003307:0000 File 00105.mpls was added as title #11
003307:0000 File 00206.m2ts was added as title #12
003307:0000 File 00205.m2ts was added as title #13
003025:0000 Title #00203.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00201.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00204.m2ts was added as title #14
003025:0000 Title #00118.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00208.m2ts was added as title #15
003025:0000 Title #00005.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00112.m2ts has length of 87 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at XXQ6ScWuaCZ1a5UClaTPlZja:0
Application exited at Wed Jan 15 16:47:14 2014
Martino
Post by Martino »
Another Disc (older Release ??) with American Gangster ripped again, no Problems
