This means that although Make MKV rips them fine, Handbrake can then not deal with the encodes as apparently they are not in it's libraries or something. You can tell I'm not very technical
So is there a way of getting MakeMKV to generate an HD file that Handbrake can read? Or failing that another way of getting the ouptut files into a format that I can put in iTunes to play through my AppleTV?
Thanks in advance.
