The Dark Knight Blu Ray
Arnold_Layne
#1 Post by Arnold_Layne » Sat Jan 11, 2014 2:26 pm
I'm getting the following error when ripping this blu ray disc. I've ripped it before using version 1.8.6 without errors, but 1.8.7 is generating error messages.
Debug log started at Sat Jan 11 13:45:11 2014 , written by MakeMKV v1.8.7 win(x64-release)
001005:0000 MakeMKV v1.8.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Steve/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=yQHrNK0Oo3rlg5P5yvWWRne5GItFFOb6p9EuNPcNGbnaAxBPYCKn+2NK73W3N9JTB12DilCERORjn++Urcdt2k9CY2u5L4ZS3FrtECKBjQlIhuptiSGWIwNFAAo5O95doGqgPqTMc58ePawDnmZYk2YzPB+PmHLgtQ==
DCE=azVHl1W02tPfTxQrRTNVrU+cw8CemZg1g1LKBZTsaLxMdlJsqbav3z7MD2W3pvtKMyHdwvCuzWnwDrI4rl3bAkOcuAM6vo2vnhz2XV15RqFZG2LemeUJVQcZFBawg5kL3L0ijZSv1jtwmHYZe3G5jf3e219uJFqMeA==
DISCID=E83AB5BDDB0A0C4F295F886436ECE1069761A0E7
003025:0000 Title #00008.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00100.mpls was added as title #0
003307:0000 File 00122.mpls was added as title #1
003307:0000 File 00201.mpls was added as title #2
003025:0000 Title #00000.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00008.m2ts is equal to title 00201.mpls and was skipped
003025:0000 Title #00002.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00005.m2ts was added as title #3
005014:0000 Saving 1 titles into directory D:/
005001:0308 File D://The_Dark_Knight_t00.mkv already exist. Do you want to overwrite it?
001003:0020 DEBUG: Code 1201 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1202 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1203 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1204 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1205 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1206 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1207 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1208 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1209 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1210 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1211 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1212 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1213 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1214 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1215 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1216 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1217 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1218 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1219 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1220 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1221 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1233 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1229 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1222 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1223 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1224 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1225 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1226 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1227 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1228 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1230 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1231 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1232 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1234 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1235 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1236 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1237 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1238 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1239 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1240 at IY2v.p;V.7|,gSWb@a:nd:121261796
001003:0020 DEBUG: Code 1253 at IY2v.p;V.7|,gSWb@a:nd:121261796
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Sat Jan 11 14:13:27 2014
Operating System
Windows 8.1 64-bit
CPU
Intel Core i7 4820K @ 3.70GHz
RAM
32.0GB DDR3 @ 800MHz
Motherboard
ASUS SABERTOOTH X79
Graphics
3071MB NVIDIA GeForce GTX 780
Storage
100GB SSD
5X4TB HDD
Optical Drives
HL-DT-ST BD-RE BH14NS40
Re: The Dark Knight Blu Ray
#2 Post by mike admin » Tue Jan 14, 2014 9:25 am
This particular error does indicate a certain condition in MakeMKV that shouldn't normally happen, but it is harmless otherwise. Is the resulting file OK? Are you opening the disc or ISO image?
Arnold_Layne
#3 Post by Arnold_Layne » Wed Jan 15, 2014 1:43 am
mike admin wrote:This particular error does indicate a certain condition in MakeMKV that shouldn't normally happen, but it is harmless otherwise. Is the resulting file OK? Are you opening the disc or ISO image?
It's from the disc. MakeMKV 1.8.6 gave the same error when I reverted back to that version as well. I now recall I didn't ahve debugging mode on when I ripped it the first time in 1.8.6. The file seems to have saved ok, but I've not had time to play through the entire movie to look for any glitches.
Steve
Operating System
Windows 8.1 64-bit
CPU
RAM
Motherboard
ASUS SABERTOOTH X79
Graphics
Storage
100GB SSD
5X4TB HDD
Optical Drives
