Wall-E (Region 2)
Antoine
Wall-E (Region 2)
Post by Antoine »
Just a quick message to report a problem with ripping the DVD of Wall-E (Region 2). It used to work with previous versions of MakeMkv. It does not anymore.
It seems to detect correctly the titles, but the actual ripping part never starts (it does not go as far as to generate a file).
Antoine
EDIT: don't ask my why. But once I posted this message, it miraculously worked! I tried unsuccessfully 10 times before that... :oops: The only thing that change between the two tests is that I changed the region of my dvd drive back and forth (to region 1, then back to region 2).
Re: Wall-E (Region 2)
With most drives, it is unnecessary to switch regions. My drives do not even have a region selected, and I've tested them with both region 1 and 2, no issues with MakeMKV.
There are, however, some drives that will reject attempts to brute-force the region code. Fortunately, the LG Bluray drives aren't that way.
