Portable version
sunken
Portable version
#1 Post by sunken » Thu Jan 09, 2014 8:26 am
Is it available? Otherwise can you release one?
Installing is so 90s :lol:
Re: Portable version
#2 Post by Woodstock » Thu Jan 09, 2014 3:53 pm
Portable would have an issue with getting low-level access to the hardware on operating systems that are not anxious to let that happen, without previously-installed libraries. Not impossible, but... if you have the permissions to allow such a version to run, you'd also have the permissions to do an install, and can use the beta key for short-term use.
