Portable version
sunken
Portable version
Post by sunken »
Is it available? Otherwise can you release one?
Installing is so 90s :lol:
Re: Portable version
Portable would have an issue with getting low-level access to the hardware on operating systems that are not anxious to let that happen, without previously-installed libraries. Not impossible, but... if you have the permissions to allow such a version to run, you'd also have the permissions to do an install, and can use the beta key for short-term use.
