0 titles saved, 1 failed
Cheddar
Post by Cheddar »
Was trying to rip a South Park blu ray and keep getting this error. The disk works fine, I cleaned it just to be sure with a damp cloth, plays just fine in my blu ray player. I tried to upload the log file but the site wont let me. I have had no problems with MakeMKV before but not all of a sudden it don't work.
Debug log started at Wed Jan 08 08:26:40 2014 , written by MakeMKV v1.8.7 win(x64-release)
001005:0000 MakeMKV v1.8.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Josh/MakeMKV_log.txt
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=Qzy0xVdz+WAGfhyUKvGiNIo+d/OFx+F7ann1FBKTltqEFMCG3rEypzvSeDxuNxQim2kvn0AWz/IBj32lM5k6WBfYrm/WBQjzVPrwuzdPYbBEdLZRpkNOPexRGQ0HVtaEsKEKkTI3x2XsJf+PMezMJlaxL11qCYDA8A==
DISCID=666EA98D6FE6619E6369A0463C7B2F1D938CFB06
003307:0000 File 00007.mpls was added as title #0
003307:0000 File 00000.mpls was added as title #1
003307:0000 File 00009.mpls was added as title #2
003025:0000 Title #00001.mpls has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00006.mpls was added as title #3
003307:0000 File 00011.mpls was added as title #4
003307:0000 File 00010.mpls was added as title #5
003307:0000 File 00005.mpls was added as title #6
003307:0000 File 00004.mpls was added as title #7
003307:0000 File 00002.mpls was added as title #8
003025:0000 Title #00006.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at cnHH3p2sNOI2wjGywVD6Ye/d:0
001003:0020 DEBUG: Code 233 at bG3B1B/ervLic5BkosHx7nOz:0
001003:0020 DEBUG: Code 233 at AVOaDuRYtZY9oHQRiORlfOUL:0
001003:0020 DEBUG: Code 233 at lWZ578rC5Y36X41ow7cp+l+k:0
001003:0020 DEBUG: Code 233 at /mo8h2+pg6IlmxkKHdkU0ZHD:0
001003:0020 DEBUG: Code 233 at 8wAFpAOpWOSwGUAjKv9WxvCp:0
001003:0020 DEBUG: Code 233 at 9z/6BofK8DfNKiDMKiicYHD1:0
001003:0020 DEBUG: Code 233 at YRBRNk6XfXzhOFE/c0BrjC+H:0
001003:0020 DEBUG: Code 233 at PG5bsfM9RvE+dmNC/YFv489T:0
001003:0020 DEBUG: Code 233 at 7IIr0mJpkZz1oAA1S8WOWY7r:0
005015:0000 Saving 1 titles into directory X:/MKV using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/flac.mmcp.xml'
FFENC003: option compression_level=5
FFDEC001: [truehd @ 0000000023d40c10] Warning: not compiled with thread support, using thread emulation
FFENC003: [flac @ 0000000023357940] Warning: not compiled with thread support, using thread emulation
FFENC003: [flac @ 0000000023357940] compression: 5
FFENC003: [flac @ 0000000023357940] lpc type: Levinson-Durbin recursion with Welch window
FFENC003: [flac @ 0000000023357940] prediction order: 1, 8
FFENC003: [flac @ 0000000023357940] order method: estimate
FFENC003: [flac @ 0000000023357940] partition order: 0, 8
FFENC003: [flac @ 0000000023357940] block size: 4608
FFENC003: [flac @ 0000000023357940] lpc precision: 15
FFDEC001: [truehd @ 0000000023d40c10] End of stream indicated.
001003:0020 DEBUG: Code 4294967295 at s*0uT`3mw8ttMCMv5wkP':213130053
001003:0020 DEBUG: Code 2 at 4gYA3'r=\2%"Wbp,:121264165
001003:0020 DEBUG: Code 0 at AsEg3|1vZX"LU'8]?q}N:29393332
001003:0020 DEBUG: Code 20 at 4gYA3'r=\2%"Wbp,:213131410
001003:0020 DEBUG: Code 0 at 4gYA3'r=\2%"Wbp,:121264763
001003:0020 DEBUG: Code 0 at IY2v.p;V.7|,gSWb@a:nd:29398622
005003:0000 Failed to save title 0 to file X:/MKV/South_Park_Season_16_-_Disc_1_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Wed Jan 08 08:36:04 2014
Re: 0 titles saved, 1 failed
Post by mike admin »
It looks like an unknown bug in audio transcoding. Please submit a test dump per instructions at /onlinehelp/testdump.html .
Cheddar
Post by Cheddar »
mike admin wrote:It looks like an unknown bug in audio transcoding. Please submit a test dump per instructions at /onlinehelp/testdump.html .
Ok I sent a test dump.
