RoboCop (remastered edition)
tylergfoster
Post by tylergfoster » Tue Jan 07, 2014 9:29 pm
Best Buy stores have just put out a new edition of RoboCop, remastered at 4K for MGM's 90th. The disc contains some new form of BD+ that MakeMKV can't crack. A few days ago, someone else using MakeMKV reported on Blu-Ray.com that the program wouldn't even work (at least, that's my understanding of what he was saying). I got it to output an MKV, but the picture is distorted, much like watching scrambled cable. Please let me know if there is some internal report or data I can post here from the program.
Re: RoboCop (remastered edition)
Post by Woodstock » Tue Jan 07, 2014 11:53 pm
During the rip, you should have seen an error message about the BD+ not generating any FUT (fix up tables). It would have given the path to a tgz file that needs to be sent to svq@makemkv.com.
Once that is done, Mike can dig out his BD Magic Wand (tm) and create an SVQ file to allow MakeMKV to decode the BD+.
tylergfoster
Post by tylergfoster » Wed Jan 08, 2014 7:07 am
Woodstock wrote:During the rip, you should have seen an error message about the BD+ not generating any FUT (fix up tables). It would have given the path to a tgz file that needs to be sent to svq@makemkv.com.
Is the tgz file accessible now, or should I rip the disc again?
Post by mike admin » Wed Jan 08, 2014 10:08 am
Not yet, should take a few more days.
Post by Woodstock » Wed Jan 08, 2014 4:26 pm
tylergfoster wrote:Is the tgz file accessible now, or should I rip the disc again?
The tgz file should probably still be on your system, but the location might be hard to find; the log gives the full path. So, ripping again will display the warning message AND give the path to the tgz file.
But, reading Mike's message, he may already have what he needs from someone else. Your option to wait or rip again.
frank22
Post by frank22 » Thu Jan 23, 2014 10:09 am
Thinking about getting Robocop 4K. Did a google search for Robocop 4k+makemkv and this is the thread that turned up.
Are there any updates to this issue, can I safely rip robocop 4k now or should I wait until Everything is in order?
frank22
Post by frank22 » Fri Jan 24, 2014 10:13 pm
Bluray will arrive next week.
Any news on update?
Post by mike admin » Sat Jan 25, 2014 8:38 am
Its done a while ago. Should work fine.
frank22
Post by frank22 » Sat Jan 25, 2014 9:12 am
mike admin wrote:Its done a while ago. Should work fine.
Thanks man, much appreciated :)
donmelton
Post by donmelton » Sat Jan 25, 2014 11:20 pm
I just got my remastered "RoboCop" today (after Amazon lost it during shipping) and I can confirm that MakeMKV 1.8.7 rips it perfectly with the "FLAC" profile.
Seriously, it's the best the film has ever looked.
Kraken
Post by Kraken » Wed Jan 29, 2014 12:41 am
Just received my UK version of the new Robocop disc, and 1.8.7 won't rip it without severe artifacting in the finished MKV.
Does this presumably have a different FUT than the US disc which 1.8.7 has been confirmed as being able to rip correctly?
I can provide the dump_RoboCop_7BB86601DD82F266.tgz file if required.
Thanks in advance.
crowfax
Post by crowfax » Wed Jan 29, 2014 3:16 am
always provide the file. send it to support at makemkv dot com
Kraken
Post by Kraken » Sat Feb 01, 2014 2:01 am
crowfax wrote:always provide the file. send it to support at makemkv dot com
Emailed the tgz file (50mb, had to rar-split it into two emails!) through on Tuesday night.
How long does an SVQ file usually take to prepare?
Thanks in advance.
Post by Woodstock » Sat Feb 01, 2014 5:18 pm
Time to SVQ varies with Mike's work load... Try ripping it in the afternoon of the next few days, and it will probably work suddenly. SVQs do not have to be manually downloaded, if you leave the MakeMKV setting to "automatic". When one appears for your disk, it will be picked up and applied.
Kraken
Post by Kraken » Sat Feb 01, 2014 5:27 pm
Woodstock wrote:Time to SVQ varies with Mike's work load... Try ripping it in the afternoon of the next few days, and it will probably work suddenly. SVQs do not have to be manually downloaded, if you leave the MakeMKV setting to "automatic". When one appears for your disk, it will be picked up and applied.
Looks like a I had a setting wrong in the UI. "General" - "Allow contacting webserver for updates" was unticked (is that usually off by default?)
Turned it on the and the software downloaded new updates and there was no FUT error after the disc was scanned. Rip in progress!
EDIT: Rip worked perfectly! Thanks for everyone's help!
