Downton Abbey -- again
MakOwner
#1 Post by MakOwner » Tue Jan 07, 2014 2:11 am
Has anyone else hit this error with the Downton Abbey DVDs? This is from the three disc season 3 set:
All three discs exhibit similar errors.
Anyone have any ideas other than it's just bad media?
Disk1
MakeMKV v1.8.6 linux(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE HL-DT-ST BD-RE WH14NS40 1.00' at offset '1048576'
The new version 1.8.7 is available for download at http://www.makemkv.com/download
Cells 10-end were skipped due to cell commands (structure protection?)
Title #1 was added (8 cell(s), 1:09:00)
Title #3 was added (7 cell(s), 0:49:27)
Title #4 was added (7 cell(s), 0:51:07)
Title #5 was added (4 cell(s), 0:48:32)
Title #6 has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 was added (1 cell(s), 0:20:50)
Title #9 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-3 were removed from title start
Cells 14-14 were removed from title end
Title #13 was added (10 cell(s), 1:10:30)
Can't locate a cell for VTS 1 TTN 8 PGCN 8 PGN 8
Saving 6 titles into directory /home/dale/Videos/_Downton_Abbey_S3_D1_FE8F
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '16627712'
Failed to save title 5 to file _Downton_Abbey_S3_D1_FE8F/title05.mkv
5 titles saved, 1 failed
Disk 2
MakeMKV v1.8.5 linux(x64-release) started
Debug logging enabled, log will be saved as MakeMKV_log.txt
Cells 9-end were skipped due to cell commands (structure protection?)
Title #1 was added (7 cell(s), 0:49:33)
Title #3 was added (6 cell(s), 0:49:36)
Title #4 was added (7 cell(s), 0:49:32)
Title #5 was added (7 cell(s), 0:50:57)
Title #8 was added (1 cell(s), 0:20:30)
DEBUG: Code 10551311 at OTHJq8~uNIzuC778:121270237
DEBUG: Code 0 at OTHJq8~uNIzuC778:121271410
DEBUG: Code 0 at ?m*D:Y5<v==~\FR,+F:213131042
Cells 13-13 were removed from title end
Title #13 was added (9 cell(s), 0:51:07)
Can't locate a cell for VTS 1 TTN 8 PGCN 8 PGN 7
Cells 2-end were skipped due to cell commands (structure protection?)
Title #15/0/1 was added (8 cell(s), 0:38:21)
Saving 7 titles into directory /home/dale/Videos/_Downton_Abbey_S3_D2_A7DF
AV synchronization issues were found in file '_Downton_Abbey_S3_D2_A7DF/Downton_Abbey_S3_D2_A7DF_t00.mkv' (title #1)
AV sync issue in stream 1 at 0:49:33.670 with duration of 6.7ms : short audio gap was removed, audio skew is -6.7ms
AV synchronization issues were found in file '_Downton_Abbey_S3_D2_A7DF/Downton_Abbey_S3_D2_A7DF_t01.mkv' (title #2)
AV sync issue in stream 1 at 0:49:35.712 with duration of 44.116ms : audio gap - 1.378 missing frame(s)
AV synchronization issues were found in file '_Downton_Abbey_S3_D2_A7DF/Downton_Abbey_S3_D2_A7DF_t02.mkv' (title #3)
AV sync issue in stream 1 at 0:49:31.668 with duration of 20.7ms : short audio gap was removed, audio skew is -20.7ms
AV synchronization issues were found in file '_Downton_Abbey_S3_D2_A7DF/Downton_Abbey_S3_D2_A7DF_t03.mkv' (title #4)
AV sync issue in stream 1 at 0:49:35.789 with duration of 96ms : 3 overlapping frame(s) dropped at segment boundary
AV sync issue in stream 1 at 0:49:35.789 with duration of 19ms : encountered overlapping frame, audio skew is +19ms
AV sync issue in stream 1 at 0:50:58.061 with duration of 41.733ms : audio gap - 1.304 missing frame(s)
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '16760832'
DEBUG: Code 0 at "Q~gk_x|-Asme=%`spMK:121262739
DEBUG: Code 0 at 71f'D6F`;?liwE}GYd/:121261681
DEBUG: Code 0 at "Q~gk_x|-Asme=%`spMK:213130743
DEBUG: Code 8184 at "Q~gk_x|-Asme=%`spMK:29393332
DEBUG: Code 0 at 7|rxt(1|C"Bgl)DmvAs.9:29398645
DEBUG: Code 0 at Cs)e,r7%RGSL;Z&+v*v:213132744
DEBUG: Code 0 at R`jV!5t. n)\?xfSE:121263728
DEBUG: Code 0 at R`jV!5t. n)\?xfSE:121263176
DEBUG: Code 0 at R`jV!5t. n)\?xfSE:29393930
Failed to save title 4 to file _Downton_Abbey_S3_D2_A7DF/Downton_Abbey_S3_D2_A7DF_t04.mkv
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '21278720'
DEBUG: Code 10390 at "Q~gk_x|-Asme=%`spMK:29393332
Failed to save title 5 to file _Downton_Abbey_S3_D2_A7DF/Downton_Abbey_S3_D2_A7DF_t05.mkv
AV synchronization issues were found in file '_Downton_Abbey_S3_D2_A7DF/Downton_Abbey_S3_D2_A7DF_t06.mkv' (title #7)
AV sync issue in stream 1 at 0:00:00.028 with duration of 192ms : 6 early frame(s) dropped at start
AV sync issue in stream 1 at 0:38:17.795 with duration of 6.7ms : short audio gap was removed, audio skew is -6.7ms
5 titles saved, 2 failed
Here is a link to the post where I reported Season two:
http://www.makemkv.com/forum2/viewtopic.php?f=7&t=5798
