blu ray disk refuses to mount
ejonesss
Post by ejonesss »
i dont know if this is the right place to post so you mods are welcome to move to the correct place
i have the movie collision earth on blu ray and the disk will not mount.
the drive attempts to read then ejects the disk.
is this a new copy protection designed to prevent ripping by force ejecting the disk (i have seen this on a cd once back in the sony rootkit days).
no mounting in the finder on mac osx.
i tried on another mac and the same thing.
i tried on a windows pc and the same thing.
i am using a sata blu ray drive pulled from a broken laptop using a usb/sata bridge board pulled from a flood ruined blu ray slim line drive.
you probably will be tempted to say that 1 or both of those may be at fault but other bluray disks work ok just not collision earth.
the problem is it will not even get to the place where i can start a backup.
while this problem is before the involvement of makemkv maybe others had this problem with some movies and can tell me if it is a copy protection or bad disk.
the studios are
cinetelfilms
movie central
the movie network
super ?cran
canada
anchor bay entertainment
additionally in fine print on the edge of the disk is colliding pictures inc
http://www.imdb.com/title/tt1887703/?ref_=fn_al_tt_1
Re: blu ray disk refuses to mount
Post by mike admin »
Launch MakeMKV first, and then insert the disc. If it is ejected then your disc is physically unreadable. Otherwise MakeMKV should open it.
