Dolby True-HD to FLAC failes
hahans
Post by hahans »
Converting my bluray with the FLAC profile always fails. The oringial audio track is Dolby True-HD 5.1, here's the debug log output:
005015:0000 Saving 1 titles into directory F:/Video/HALO_22 using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/flac.mmcp.xml'
FFENC004: option compression_level=5
FFDEC001: [truehd @ 000000002382fb30] Warning: not compiled with thread support, using thread emulation
FFENC004: [flac @ 0000000023972010] Warning: not compiled with thread support, using thread emulation
FFENC004: [flac @ 0000000023972010]  compression: 5
FFENC004: [flac @ 0000000023972010]  lpc type: Levinson-Durbin recursion with Welch window
FFENC004: [flac @ 0000000023972010]  prediction order: 1, 8
FFENC004: [flac @ 0000000023972010]  order method: estimate
FFENC004: [flac @ 0000000023972010]  partition order: 0, 8
FFENC004: [flac @ 0000000023972010]  block size: 4608
FFENC004: [flac @ 0000000023972010]  lpc precision: 15
FFDEC002: [truehd @ 000000003541d010] Warning: not compiled with thread support, using thread emulation
FFDEC003: [truehd @ 000000003548c100] Warning: not compiled with thread support, using thread emulation
FFDEC003: [truehd @ 000000003548c100] End of stream indicated.
001003:0020 DEBUG: Code 4294967295 at s*0uT`3mw8ttMCMv5wkP':213130053
001003:0020 DEBUG: Code 2 at 4gYA3'r=\2%"Wbp,:121264165
001003:0020 DEBUG: Code 0 at AsEg3|1vZX"LU'8]?q}N:29393332
001003:0020 DEBUG: Code 20 at 4gYA3'r=\2%"Wbp,:213131410
001003:0020 DEBUG: Code 0 at 4gYA3'r=\2%"Wbp,:121264763
001003:0020 DEBUG: Code 0 at IY2v.p;V.7|,gSWb@a:nd:29398622
005003:0000 Failed to save title 0 to file F:/Video/HALO_22/title00.mkv
005004:0080 0 titles saved, 1 failed
Creating a mkv with default settings does work however, so it has something to do with the FLAC conversion..? Tried several times, always the same error message.
Any ideas?
Re: Dolby True-HD to FLAC failes
Post by mike admin »
Please submit a testdump for the title per instructions at /onlinehelp/testdump.html .
Thanks a lot for the dump. Bug will be fixed in the next version, same issue as http://www.makemkv.com/forum2/viewtopic.php?f=1&t=7421
