Hansel and Gretel Witch Hunters
Dutch
#1 Post by Dutch » Sat Jan 04, 2014 10:59 am
The copy does not work with Bluray "Hansel and Gretel Witch Hunters"
Below is the error report:
Saving 1 titles into directory D:/Temp_Video
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4814665728'
Failed to save title 0 to file D:/Temp_Video/Hansel_and_Gretel_Witch_Hunters_t00.mkv
0 titles saved, 1 failed
Re: Hansel and Gretel Witch Hunters
#2 Post by Woodstock » Sat Jan 04, 2014 8:01 pm
The error message given looks like a disk issue - the request was legal until it reached a large offset into one of the files being read, then it was illegal. If there was an issue with the AACS key, it would normally show up very early in the run. And, once the drive decided it was having a problem, MakeMKV could not do much about it.
Standard advice for disk issues is to start with cleaning it.
After that, make sure you have debugging turned on, and post the log generated, not just the part with the error.
Dutch
#3 Post by Dutch » Sun Jan 05, 2014 2:36 pm
This is a disc effectivment erreure. On a Bluray player stops playing at 15:51 and resumed at 16:15 minutes.
Thank you for the reply.
Below is the full report:
MakeMKV v1.8.7 win(x64-release) started
File 00800.mpls was added as title #0
Title #01000.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00250.m2ts was added as title #1
File 00251.m2ts was added as title #2
File 00252.m2ts was added as title #3
Title #00021.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4808699904'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4808835072'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4808964096'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4810211328'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4810340352'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4810407936'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4810536960'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4810604544'
RandyB
#4 Post by RandyB » Mon Jun 16, 2014 12:21 pm
Hmmm, more than 5 months later looks like this is still an unresolved problem.
I have tried twice with two brand new Blu Ray discs of Hansel & Gretel Unrated version and I get the exact same error. 4 attempts same error, highly unlikely it is a bad disc or dirty one. Both were clean, they play fine Makemkv fails to work on this one.
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset [multiple lines of same error with different #]
#5 Post by Woodstock » Mon Jun 16, 2014 11:59 pm
RandyB, are you using the same version of MakeMKV as the original poster? Are the errors you are receiving the same as the OP?
If not, a debug log would be appropriate to add to your message.
