How do I create a MKV with SBS 3D?
Everything related to Blu-ray 3D and 3D MKV files
TheBatman
Post by TheBatman » Mon Dec 09, 2013 12:10 pm
Hello!
So what I have gathered is that I need to tick the MVC video track, which is what I have done, now the problem is that I cannot figure out how to get the TWO(left and right eye) bluray 3D tracks in SBS configuration. Here's what it looks like before I make it an MKV:
This gives me two 35GB mkv files with the following media info:
General
Unique ID                      : 107025324795005796193844298347669180170 (0x508453E996FBA2B4403C577CC2294F0A)
Complete name                  : T:\Backup\BluRay\The Hobbit An Unexpected Journey\DISC1\The_Hobbit_An_Unexpected_Journey_Extended_Edition_Part_1_t01.mk3d
Format                         : Matroska
Format version                 : Version 2
File size                      : 29.9 GiB
Duration                       : 1h 39mn
Overall bit rate mode          : Variable
Overall bit rate               : 43.2 Mbps
Movie name                     : The Hobbit: An Unexpected Journey Extended Edition Part 1
Encoded date                   : UTC 2013-12-09 11:13:35
Writing application            : MakeMKV v1.8.6 win(x64-release)
Writing library                : libmakemkv v1.8.6 (1.2.0/1.1.0) win(x64-release)
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : Stereo High@L4.1 / High@L4.1
MultiView_Count                : 2
Format settings, CABAC         : Yes
Format settings, ReFrames      : 2 frames
Codec ID                       : V_MPEG4/ISO/AVC
Duration                       : 1h 39mn
Bit rate mode                  : Variable
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 23.976 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Language                       : English
Default                        : No
Forced                         : No
Audio
Format                         : DTS
Format/Info                    : Digital Theater Systems
Format profile                 : MA / Core
Mode                           : 16
Format settings, Endianness    : Big
Codec ID                       : A_DTS
Duration                       : 1h 39mn
Bit rate                       : Unknown / 1 509 Kbps
Channel count                  : 8 channels / 6 channels
Channel positions              : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                  : 48.0 KHz
Bit depth                      : 24 bits
Compression mode               : Lossless / Lossy
Title                          : Lossless
Language                       : English
Default                        : Yes
Forced                         : No
Menu
00:00:00.000                   : en:Chapter 01
00:10:11.902                   : en:Chapter 02
00:14:08.681                   : en:Chapter 03
00:17:27.254                   : en:Chapter 04
00:18:44.623                   : en:Chapter 05
00:23:16.603                   : en:Chapter 06
00:27:59.469                   : en:Chapter 07
00:36:04.871                   : en:Chapter 08
00:41:17.266                   : en:Chapter 09
00:46:30.829                   : en:Chapter 10
00:53:04.181                   : en:Chapter 11
00:58:07.650                   : en:Chapter 12
00:59:55.300                   : en:Chapter 13
01:10:42.404                   : en:Chapter 14
01:15:01.830                   : en:Chapter 15
01:18:52.811                   : en:Chapter 16
01:24:56.925                   : en:Chapter 17
01:30:34.429                   : en:Chapter 18
01:34:10.603                   : en:Chapter 19
01:37:24.463                   : en:Chapter 20
I do know that this track is only 1/2 the movie, since the other half is on another disc, which I will bother with once I get the hold of this.
Now I have been trying to make it with MKVToolNix, which no success, since the only thing I have managed was to put two identical tracks in the same MKV with steoroscopy set to SBS(left first) for the first track and SBS(right first) for the second track.
Anyone? Thanks in advance!
ZheParadox
Re: How do I create a MKV with SBS 3D?
Post by ZheParadox » Fri Jan 03, 2014 6:12 pm
heyho...
did you figure it out?
i have the exact same issue right now and also with the hobbit :S
hope to hear from you
