DVD: Riverdance (from NYC) - fails at end
BestGear
Post by BestGear » Thu Jan 02, 2014 10:57 am
Guys
First post here, so hi all, and hopefully I haven not missed the answer to this while searching!
Trying to run makeMKV against Riverdance DVD and it completed the copy process and states " operation successfully completed" and then fails to save the title.
I have tried different DVD drives and also output file destinations and all give the same error.
The chapter size (just one being extracted) is 2.4gb.
Any clues or other things I can try?
I also copied the DVD to an ISO and tried MakeMKV against the ISO with the same result.
David
BestGear
Re: DVD: Riverdance (from NYC) - fails at end
Post by BestGear » Thu Jan 02, 2014 11:21 am
Hi
I just enabled debug, and clicked expert mode... and increased the read buffer size and it now ran without error.
Any ideas?
I would not expect the above to have changed anything!
Dvaid
BestGear
Post by BestGear » Thu Jan 02, 2014 11:34 am
Ok...spoke too soon...
Tried other disc and error is back...
Saving 1 titles into directory U:/Inbound Video/Music Videos/Riverdance - Live from NYC (1998)/Riverdance - Live from NYC - Disc 2 (1998)
DEBUG: Code 449 at P~uuJsYqOj@Mw0//+sc:213135895
DEBUG: Code 0 at IY2v.p;V.7|,gSWb@a:nd:29398622
DEBUG: Code 0 at 1LPq}2;dMC1|13,mD:121263728
DEBUG: Code 0 at 1LPq}2;dMC1|13,mD:121263176
DEBUG: Code 0 at 1LPq}2;dMC1|13,mD:29393930
DEBUG: Code 0 at IY2v.p;V.7|,gSWb@a:nd:29398990
Failed to save title 0 to file U:/Inbound Video/Music Videos/Riverdance - Live from NYC (1998)/Riverdance - Live from NYC - Disc 2 (1998)/title00.mkv
0 titles saved, 1 failed
Just created an ISO with DVD decrypter and then makemkv... same error as above. DVD decrypter produced no error when reading the disc.
Post by mike admin » Fri Jan 03, 2014 5:57 am
This is an error in video stream that MakeMKV failed to work around automatically. Please send the full log file (see the first line for location) to support@makemkv.com and workaround will be added in the next version.
