DVD error
e-gray1975
DVD error
#1 Post by e-gray1975 » Tue Dec 31, 2013 8:58 am
I have been using Make Mkv for a while now with no problems until not.
I am trying to back up a dvd film (HEAT 1995) but coming up with failed.
Log as follows.
MakeMKV v1.8.7 win(x64-release) started
Title #1 was added (52 cell(s), 2:43:09)
Title #2 was added (1 cell(s), 0:00:12)
Audio stream #2 is identical to stream #1 and was skipped
Subtitle stream #4 is identical to stream #3 and was skipped
Subtitle stream #5 is identical to stream #3 and was skipped
Subtitle stream #6 is identical to stream #3 and was skipped
Subtitle stream #7 is identical to stream #3 and was skipped
Subtitle stream #8 is identical to stream #3 and was skipped
Subtitle stream #9 is identical to stream #3 and was skipped
Subtitle stream #10 is identical to stream #3 and was skipped
Subtitle stream #11 is identical to stream #3 and was skipped
Subtitle stream #12 is identical to stream #3 and was skipped
Saving 1 titles into directory C:/To Be Handbraked
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '3030495232'
Failed to save title 0 to file C:/To Be Handbraked/title00.mkv
0 titles saved, 1 failed
Any help will be appreciated.
Re: DVD error
#2 Post by Woodstock » Tue Dec 31, 2013 2:43 pm
The medium errors are because your drive cannot read parts of the disk. When that happens, the rip fails.
Standard drill is, clean the disk. My personal addition to that is cleaning using something like Pledge furniture polish, which applies a thin coat of wax while it cleans.
There are steps beyond cleaning, up to and including getting the disk replaced, but start with cleaning. It's also possible the drive is getting dirty, but that will show up with errors on multiple disks.
dannyboy48888
Re: DVD error
#3 Post by dannyboy48888 » Wed Jan 01, 2014 4:43 am
I get these errors also even though the disc looks fine, Problem is when they stamp the DVD after while the stamp wears out so the disc will fail quicker or right away (bought a few I had to wait a bit to exchange so a new batch is circulated). Odds are if this is the only disc to do this than it's the disc. First do Woodstock's advice! (trying the pledge trick now) :D
